I have a board here..
It uses a daughter-board configuration..
The "base" board is a PCI to USB adapter (NEC based).
The Attic board is a T1 interface with a USB system interface..
The creater didn't seem to realize what they had come up with...
With the correct drivers and system integration we will have hot pluggable T1 and T3 interfaces soon...
I am still waiting for the driver to be made available so I can FedEx the whole thing to the boys...
I have access to an inexpensive PCI and PCIE based T1 (single dual and quad) ... (IN PRODUCTION UNITS)
I have drivers fro that one and the MFG is 1/4 mile away, so support issues should be easy to solve...
I just need the drivers included into RouterOS.. (Hint Hint Pester, Pester...)
Also along the USB front.. with this card, (the mini PCI to USB) we can add bridge devices for SATA storage for CALEA/Proxy data (I know CF...) but try and come up with a mirroring 120GB CF solution.. I dare you...
I have scrounged up a 3.5" device that mirrors two 2.5" SATA devices and treats them as one 3.5" sata device.
It provides for mirroring or striping and hot plug SATA storage and has a 3.5" form factor...
