I Have problem since upgrade my ROS from 2.9.38 to 3.9 -> 3.10 (same problem on RB532), the problem is in (Simple Queues - Show Columns), usualy i like to show Tx Avg.Rate & Rx Avg.Rate (i use this columns, for monitor my user bandwith usage), this very helpfull, when the first time i upgrade my ROS from 2.9.38 to 3.9, I just login, and click Queues, but this columns does'nt show up, so i just right click to show "Tx Avg.Rate & Rx Avg.Rate", it's ok, but when i was logout, and login again via winbox, this columns not show, and the Queues columns looks like reset, so i must ajustment every single columns and right click to show "Tx Avg.Rate & Rx Avg.Rate" (this situation happen every time i logout from the system, even i was upgrade again to ROS 3.10, still same problem), maybe there is solutions about this ? please help me , this problem not happen on RB133 and RB333, cause i was upgrade my ROS on RB133 & RB333 with ROS 3.9 it's work fine.
Best Regards
Boyke
