cnokafor
Hyper terminal logon
Tue Jul 15, 2008 11:34 am
I use a mikrotik routerboard230 and was trying to setup the hotspot feature. ALong the line i got knocked off by the router and i am not able to log on again. I need to be able to logon and correct whatever error i made but i can't use winbox anymore as i am not able to log on.
I want to use hyperteminal. when i boot the router i see the booting information and that is all, i don't get as far as where to log on. The router gives the two beeps that shows it has complete it's booting process.
I use com1, 9600 bits per secons, 8 data bits, parity: none, stop bits:1, and hardware for flow control. what else am i to do to be to able to logon to the routerboard and revert what i did.
Chris
janisk
Re: Hyper terminal logon
Tue Jul 15, 2008 3:20 pm
after you hear double beep, try to connect to router using 112500 baud rate, maybe that has been changed in settings.
also, maybe your console is disabled (under /system console)
you can try mac-telnet (mac-winbox)
cnokafor
Tue Jul 15, 2008 8:38 pm
i tried using 115200 it did not work. I think it is not accepting any tcpip logon. I tried the neighborhood viewer to log on, it brings the logon page, i enter the username and password (for mac telnet) but after a while it just tells me "connection timeout". what other means do you suggest i use as i do not have consolve cable to log on. please
janisk
Thu Jul 17, 2008 2:53 pm
if you do not have console cable, where did you set those bit rates then? :shock:
bit rates are for console connection.
cnokafor
Thu Jul 17, 2008 4:48 pm
I used a console cable i got but it did not work. someone from the forum suggested i use neighborhood viewer and that was what i tried telneting into the routerboad with the mac. that as well did not work as i always got "connection timeout" .
what else do you suggest pls.
Users browsing this forum: florentrivoire and 6 guests
