This is my first time using the microtik router OS. I have a RB450 from wisp-router, and 3 cisco access points. In this instance, I want to run a DSL line into ethernet1, and then my 3 APs on ethernet2, 3, and 4. I want to disable ethernet5. Here is what I have done so far.
DHCP-Client setup on ethernet1 via setup command. Disabled ethernet5 interface> set 4 disable=yes
Now it looks like this router came preconfigured with some 10.x.x.x ip stuff in it. I am thinking I want to blast that out, but not sure how. So here is what i still need to do.
-get rid of any default stuff from wisp-router -assign IP addresses to my 3 cisco APs -setup ethernet2,3,4 to hand out IP address via the APs -setup the router in hotspot mode and redirect http traffic to a "splash page" by default
Can anyone point me in the right direction? I am looking at the wiki now, and making progress, but would like a little more "scenario" help. Thanks!
Users browsing this forum: No registered users and 8 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
