• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
[ask] reset rb450 ros  Page 1 of 1
 [ 14 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
cyberwolfer
 Post subject: [ask] reset rb450 ros
PostPosted: Sat Aug 08, 2009 7:19 am
Offline
dear all,
I just wanna know how to do reset rb450 ros back to default cause I forget the password.
I just see the scheme but do not know exactly which one are ROS Reset on board...
And how to do that? just like RB433 or any other way? thanks.
Rgds.
Top
 Profile
mrz
 Post subject: Re: [ask] reset rb450 ros
PostPosted: Sat Aug 08, 2009 5:29 pm
Offline
http://wiki.mikrotik.com/wiki/MikroTik_ ... d_Recovery
Top
 Profile
rgunderson
PostPosted: Sun Aug 23, 2009 7:39 am
Offline
What if this doesnt work?
Top
 Profile
QpoX
PostPosted: Sun Aug 23, 2009 6:08 pm
Offline
Then you use Netinstall...
http://wiki.mikrotik.com/wiki/Netinstall
Top
 Profile
normis
PostPosted: Mon Aug 24, 2009 8:18 am
Offline
Why wouldn't it work? It will work
_________________
Top
 Profile
rgunderson
PostPosted: Wed Sep 02, 2009 6:53 am
Offline
Well, to be fair. I have a RB153 that wont reset. Obviously it doesnt have the hole, but the jumper will not reset the pw either :(
Top
 Profile
mrz
PostPosted: Wed Sep 02, 2009 8:26 am
Offline
Then only option is to use netinstall.
Top
 Profile
jemsenator
PostPosted: Mon Apr 04, 2011 9:13 am
Offline
Urgent !!!
Please I am using RB450, Just tried to upgrade to ROS 5.0, I installed ROS 5.0 via file, and my RB450 will not boot properly, I never heard the double-beep sound, please advice, my network is down, please help. I tried the reset botton ,but it didnt work
THanks
Top
 Profile
mrz
PostPosted: Mon Apr 04, 2011 9:51 am
Offline
Connect serial cable and look what errors router show.
Top
 Profile
jemsenator
PostPosted: Mon Apr 04, 2011 10:44 am
Offline
Please how do I use the serial cable, how do I see whats wrong with the router, what command do I enter via my pc to assess the modem via the serial cable, please, I njeed clear direction so I dont make mistake, I have connected a cable with serial (to RB450) and RG45(to PC). That is serial to USB cable, Is that the right cable and procedure? Please am expecting your response
Top
 Profile
mrz
PostPosted: Mon Apr 04, 2011 11:01 am
Offline
follow instructions from the manual
http://wiki.mikrotik.com/wiki/Manual:Fi ... rial_Cable
Top
 Profile
jemsenator
PostPosted: Tue Apr 05, 2011 2:57 pm
Offline
With the console cable connected and powered on, with hyperterminal window opened, I did not see anything on the screen, I rebooted severally, still same, connected a lan cable, light came on on the LAN, with limite connectivity, waited and activated winbox, cannot see mac address or IP, please what do I do, my network is down, please help,
Top
 Profile
QpoX
PostPosted: Tue Apr 05, 2011 4:32 pm
Offline
Try and plug the network cable into the other ports, and see if winbox then finds it.
Do you use the correct setup on the serial port? (115200bit/s, 8 data bits, 1 stop bit, no parity, flow control=none).
And do you use a null-modem cable??? since you don't see anything, this might be your problem.
Top
 Profile
jemsenator
PostPosted: Wed Apr 06, 2011 6:45 pm
Offline
Finally I have been able to gain access via console cable, the RB says halted, giving options, what do I do to get it back to normal, thanks
RouterBOOT booter 2.18
RouterBoard 450
CPU frequency: 300 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup.
RouterBOOT-2.18
What do you want to configure?
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
f - cpu frequency
r - reset booter configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
t - do memory testing
x - exit setup
your choice:
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 14 posts ]
Board index » Other topics » RouterBOARD hardware
Users browsing this forum: No registered users and 5 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
