bloodmaster
RESET BUTTON ON RB 750
Sun Sep 06, 2009 1:36 am
Hi
I have try to reset the 750rb with the button but it doesnt work - i cant log in with winbox and i want some help to reset it to default settings.
Thank
bloodmaster
Re: RESET BUTTON ON RB 750
Sun Sep 06, 2009 2:03 am
solution found - thanks
roc-noc.com
Forum Veteran
Forum Veteran
Sun Sep 06, 2009 6:45 pm
And the solution is?
Please be willing to share your solutions.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
johnvam
Mon Sep 07, 2009 2:39 pm
yes...
tell us what's the solution because I have the same RB also...
izakuf
Mon Sep 07, 2009 4:55 pm
It would have been nice if you shared... I just wasted half an hour trying to figure it out... :)
The solution for me on the RB750 was to hold in the reset button while cycling the power...
Hope this helps someone :D
janisk
Tue Sep 08, 2009 3:47 pm
basically you have to hold reset button a while longer, or even longer to boot it from network, so you could netinstall it. User manual has that information written in it.
bloodmaster
Wed Sep 09, 2009 12:47 pm
Sorry for my answer delay - i was on place without pc
"The solution for me on the RB750 was to hold in the reset button while cycling the power..."
This is what i did and it works
tombee79
Sun May 16, 2010 7:42 pm
worked for me, THANKS , holding the reset button in while turn on/off power.
csickles
Sun May 16, 2010 10:34 pm
Oh I hate that RTFM thing... (READ THE F#$%#ng Manuals)
I usualy eat the manuals... Yum !! :lol:
What fun can you have beating your head against the table, if you have the answers in front of you !! :wink:
Besides, my Dr. needs the retirement fund.. (Visits for the Concussions)
Things that make you go "Hmmmmmmmm"...
Craig
mkmmkm
Sat Jun 19, 2010 6:41 pm
Hi every one. I am new on Mikrotik.
I bought RB 750G.
I have the same reset switch as you had.
When I hold down The reset button by Screwdriver, Nothing happened.
But when I disconnected power cord and Hold reset button until I connected power cord in to the DC jack, then the "ACT" LED Blinks and finally my router OS reset as well as Default factory.
SO, just by holding the reset button, It can't reset itself.
Does my router have hardware problem?
arepexz
Mon Apr 18, 2011 7:51 pm
it's work...
now i dont know to configure again :( :( :(
bburley
Fri May 06, 2011 1:21 pm
I would like to mention to be careful with the reset button on the RB750G. I had one with weak solder and I accidentally pushed the switch right off of the board. Fortunately, I know how to solder small stuff and I repaired it. It isn't much fun when you lose the ability to reset the router :(
aadi501
Wed May 23, 2012 12:48 am
Hi
Thank
janisk
Wed May 23, 2012 11:19 am
please head over to routerboard.com and download product brochure - there is detailed description on how that can be done and how reset button should be used.
tjc
Thu May 24, 2012 5:41 am
Most current RB devices have reset pads intended to be bridged with a screw driver or other metal tool. So even if you break the reset switch there is still a reset option. For example on the RB750, RB750G, and RB750GL the pads are accessible via an opening under one of the stick on silicon feet.
http://wiki.mikrotik.com/wiki/Manual:Password_reset
Users browsing this forum: florentrivoire and 9 guests
