Flavioweb
Ros 4.xx and 3.xx interoperabilty...
Wed Oct 14, 2009 12:57 pm
It's safe to upgrade rb 133 and 112 to ROS 4 and connect to an AP with 3.xx installed?
Can i have some problems doing this?
eneimi
Re: Ros 4.xx and 3.xx interoperabilty...
Wed Oct 14, 2009 8:46 pm
Sure - if your license permits. However I don't think those boards were projected to live this long! From personal experience RB133 doesn't do so good with v3.x. I would stick with 2.9.51.
Sure you can.
Only problem I can envisage is that the RB133 and RB112 don't have what it takes to run v4.x smoothly. Some user did mention that installing only the packages you will use (system, routerboard, dhcp, hotspot for example) may help.
xezen
Long time Member
Long time Member
Wed Oct 14, 2009 10:16 pm
well i did a test with 4 on 133c and no problems upgraded from 2.9.51 to v4
and works well
allmost know diffrence between 2.9.51 and 4 exept all extras
but with some packages installed here a pic to help explane
Users browsing this forum: No registered users and 40 guests
