gmidia
RB1000 Vs Duo 2 Core Machine
Tue Dec 15, 2009 10:42 pm
Apart from the 4 Giga ethernet Ports which is on the 1000 as opposed to say 2 Giga ethernet ports on a duo 2 core machine which one would out do the other. Can anybody give the advantages and disadvantage of each
normis
Re: RB1000 Vs Duo 2 Core Machine
Wed Dec 16, 2009 8:50 am
RB1000 has a specialized networking CPU which gives it huge speed advantages in many areas. It is specifically created for RouterOS and will always have the best support and compatibility.
ste
Wed Dec 16, 2009 2:53 pm
RB1000 boots fast like hell, eats low Power, is fast, small and cheap. Your question should be if it's fast enough
for your application. If it does the job there is no question.
gmidia
Wed Dec 16, 2009 3:31 pm
what am looking for here is performance. Booting applies to the other too, some X86 can be rack mounted which means small, cheap not really i can get a duo 2 Core at a cheaper price.
when you say huge speed advantages in many areas please be a bit specific so that i may get the areas.
ginovilla
Wed Dec 16, 2009 5:52 pm
We are seeing great results with Atom 330 based 1u appliance, 2 integrated GE interfaces + Intel 4 port PCIE GB card
janisk
Fri Dec 18, 2009 3:53 pm
for example, IPSec encryption throughput, as that is done on RB1000
Ozelo
Fri Feb 05, 2010 2:21 pm
Ive switched a DELL machine with a AMD Opteron inside running 200mbits link for a RB1000. I would like to say that RB1000 is indeed better for network but still lack a lot CPU power. On that DELL machine I could bwtest about 270mbits, now with RB1000 I can send/receive about 450mbits. Unfortunately, CPU is totally depleted in contrast with the DELL machine that never got above 40%. I was in the hope that it could be twice better than that, then I could implement more stuff on it like a good QoS. Well, switching back to that AMD Opteron then...
Im disapointed a bit, hope we can have an "RB2000" stuff running at least more cores such MPC8572E multi-core PPC or even better. Maybe it was done as it had the purpose for... cheap.
Ozelo
InoX
Fri Feb 05, 2010 3:53 pm
btest uses only one core, so on a dual core you will never see 100% cpu usage, only 50%. 100% on one core means 50% for the system. 25% for quad etc.
janisk
Thu Feb 11, 2010 12:34 pm
performance of router is not how much it can generate, but its throughput of traffic. Your observation Ozelo is kind of flawed that way.
Ozelo
Mon Feb 15, 2010 3:36 pm
I am sorry, I didn't write it correctly. RB1000 got 100% cpu under NORMAL traffic load less than 160 mbits. There was two interfaces for ISP @ 100mbits each, one interface for local networks and one interface for services. Ive switched this device at 6:00AM, then it got bad responses and high latency at 11:00AM... Our traffic peak is at 2:00PM witch was NOT possible to keep with a RB1000, then we switched back to that DELL Opteron, two interfaces are one Intel PRO 1000 and other two separate gigabits NIC. Conntrack is on, some mangle rules to make policy routing and about 600 routes. DEFINATELY, I was NOT referring BWTEST who depleted the RB1000 CPU, please. INSTEAD OF THAT, I was telling you all that RB1000 can "generate" much a lot traffic than the DELL Opteron!! Read it carefully.
YES, I understand that I cannot BWTEST @ 100% cpu power on multi-cores. NO, my test is NOT flawed but empiric. Anyone can come here and see by your selfs.
Come one, RB1000 was "supposed" to work better in place of that DELL Opteron core router, but I can ASSURE YOU that it cannot do the job there. NICs are great, but RB1000 sill lack CPU power.
normis
Mon Feb 15, 2010 3:42 pm
Not possible, your test must be flawed. 160Mbit is nothing for RB1000, it can easily handle much more without much CPU usage
Ozelo
Mon Feb 15, 2010 3:58 pm
Perhaps you want to check its configuration before come here and take a coffee with me. ;)
set 0 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes l2mtu=1600 \
mtu=1500 name=Services speed=1Gbps
set 1 arp=proxy-arp auto-negotiation=no cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes \
mtu=1500 name=Net1 speed=100Mbps
set 2 arp=proxy-arp auto-negotiation=no cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes \
mtu=1500 name=Net2 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=\
mtu=1500 name=Local speed=1Gbps
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
/port
set 0 baud-rate=9600 data-bits=8 flow-control=hardware name=serial0 parity=none stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default use-compression=default use-encryption=default use-vj-compression=\
default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption only-one=default use-compression=default use-encryption=yes \
use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=100000
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=100000
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 \
red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pfifo name=p2p pfifo-limit=50
set default-small kind=pfifo name=default-small pfifo-limit=100000
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" direction=both disabled=no dst-address=0.0.0.0/0 interface=all \
limit-at=0/0 max-limit=1M/1M name=rubi parent=none priority=8 queue=default-small/default-small target-addresses=X.X.X.X/32 \
total-queue=default-small
limit-at=0/0 max-limit=1M/1M name="Sta Casa Server" parent=none priority=8 queue=default-small/default-small target-addresses=\
X.X.X.X/32 total-queue=default-small
limit-at=256k/256k max-limit=256k/256k name=p2p p2p=all-p2p parent=none priority=8 queue=p2p/p2p time=\
11h-23h,sun,mon,tue,wed,thu,fri,sat total-queue=p2p
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" direction=upload disabled=no dst-address=0.0.0.0/0 interface=Services \
limit-at=0/0 max-limit=60M/0 name=Mail parent=none priority=8 queue=default-small/default-small target-addresses=X.X.X.X/32 \
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no ignore-as-path-len=no name=default out-filter="" \
redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf instance
set default comment="" disabled=no distribute-default=if-installed-as-type-1 in-filter=ospf-in metric-bgp=0 metric-connected=0 \
metric-default=1 metric-other-ospf=auto metric-rip=0 metric-static=0 name=default out-filter=ospf-out redistribute-bgp=no \
redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=X.X.X.X
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=backbone type=default
/snmp
set contact="" enabled=yes engine-boots=18 engine-id="" location="" time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set GBsnmp address=X.X.X.X/29 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=GBsnmp read-access=yes security=none write-access=no
add address=X.X.X.X/25 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=\
prtg read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=X.X.X.X:514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=\
remote
/user group
add comment="" name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,!ftp,!write,!policy
add comment="" name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,!ftp,!policy
add comment="" name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=\
FE:C1:FF:75:A5:75 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=\
disabled
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=X.X.126.1/25 comment="" disabled=no interface=Local
add address=X.X.0.1/16 comment="" disabled=no interface=Local
add address=X.X.237.30/30 comment="" disabled=no interface=Net1
add address=X.X.190.249/29 comment="" disabled=no interface=Services
add address=X.X.209.249/29 comment="" disabled=no interface=Services
add address=X.X.145.6/30 comment="" disabled=no interface=Net2
add address=X.X.0.4/16 comment="old slave" disabled=no interface=Local
add address=X.X.126.4/25 comment="old slave" disabled=no interface=Local
add address=X.X.126.5/25 comment="old master" disabled=no interface=Local
add address=X.X.0.183/16 comment="old master" disabled=no interface=Local
add address=X.X.0.23/16 comment="old dude server" disabled=no interface=Local
add address=X.X.0.19/29 comment="old dude server" disabled=no interface=Local
add address=X.X.126.23/25 comment="old dude server" disabled=no interface=Local
add address=X.X.92.129/29 comment="" disabled=no interface=Services
add address=X.X.0.185/29 comment="" disabled=no interface=Local
/ip arp
add address=X.X.237.29 comment="" disabled=no interface=Net1
add address=X.X.145.5 comment="" disabled=no interface=Net2
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=30m cache-size=10000KiB max-udp-packet-size=512 primary-dns=X.X.X.251 secondary-dns=\
X.X.X.250
/ip firewall address-list
add address=X.X.126.0/25 comment="" disabled=no list=net1
add address=X.X.254.0/24 comment="" disabled=no list=net2
add address=X.X.209.0/24 comment="" disabled=no list=net2
add address=X.X.61.72/29 comment="" disabled=no list=net2
add address=X.X.61.88/29 comment="" disabled=no list=net2
add address=X.X.61.128/29 comment="" disabled=no list=net2
add address=X.X.61.176/29 comment="" disabled=no list=net2
add address=X.X.190.0/24 comment="" disabled=no list=net1
add address=X.X.206.0/26 comment="" disabled=no list=net1
add address=X.X.224.168/29 comment="" disabled=no list=net1
add address=X.X.250.192/26 comment="" disabled=no list=net1
add address=X.X.84.128/26 comment="" disabled=no list=net1
add address=X.X.36.176/29 comment="" disabled=no list=net1
add address=X.X.102.112/29 comment="" disabled=no list=net1
add address=X.X.107.128/25 comment="" disabled=no list=net1
add address=X.X.119.144/29 comment="" disabled=no list=net1
add address=X.X.95.0/24 comment="" disabled=no list=net2
add address=X.X.227.0/24 comment="" disabled=no list=net1
add address=X.X.228.0/24 comment="" disabled=no list=net2
add address=X.X.237.28/30 comment="" disabled=no list=net1
add address=X.X.145.4/30 comment="" disabled=no list=net2
add address=X.X.125.0/24 comment="" disabled=no list=net1
add address=X.X.182.0/24 comment="" disabled=no list=net2
add address=X.X.191.0/24 comment="" disabled=no list=net2
add address=X.X.17.0/24 comment="" disabled=no list=net1
add address=X.X.42.0/24 comment="" disabled=no list=net2
add address=X.X.248.0/24 comment="" disabled=no list=net1
add address=X.X.94.0/24 comment="" disabled=no list=net1
add address=X.X.15.0/24 comment="" disabled=no list=net2
add address=X.X.21.0/24 comment="" disabled=no list=net1
add address=X.X.23.0/24 comment="" disabled=no list=net1
add address=X.X.22.0/24 comment="" disabled=no list=net1
add address=X.X.20.0/24 comment="" disabled=no list=net1
add address=X.X.197.0/24 comment="" disabled=no list=net2
add address=X.X.110.0/24 comment="" disabled=no list=net1
add address=X.X.111.0/24 comment="" disabled=no list=net1
add address=X.X.170.0/24 comment="" disabled=no list=net2
add address=X.X.237.28/30 comment="" disabled=no list=lp1
add address=X.X.145.4/30 comment="" disabled=no list=lp2
add address=X.X.104.0/24 comment="" disabled=no list=net1
add address=X.X.105.0/24 comment="" disabled=no list=net1
add address=X.X.153.0/24 comment="" disabled=no list=net2
add address=X.X.88.0/24 comment="" disabled=no list=net2
add address=X.X.90.0/24 comment="" disabled=no list=net2
add address=X.X.91.0/24 comment="" disabled=no list=net2
add address=X.X.89.0/24 comment="" disabled=no list=net2
add address=X.X.92.0/24 comment="" disabled=no list=net1
add address=X.X.93.0/24 comment="" disabled=no list=net1
add address=X.X.95.0/24 comment="" disabled=no list=net1
add address=X.X.152.0/24 comment="" disabled=no list=net2
add address=X.X.209.2 comment="" disabled=no list=allow_ssh
add address=X.X.126.11 comment="" disabled=no list=allow_ssh
add address=X.X.171.182 comment="" disabled=no list=allow_ssh
add address=X.X.227.8/29 comment="" disabled=no list=allow_ssh
add address=X.X.119.144/29 comment="" disabled=no list=allow_ssh
add address=X.X.61.94 comment="" disabled=no list=allow_ssh
add address=X.X.209.34 comment="" disabled=no list=allow_ssh
add address=X.X.209.38 comment="" disabled=no list=allow_ssh
add address=X.X.209.214 comment="" disabled=no list=allow_ssh
add address=X.X.209.162 comment="" disabled=no list=allow_ssh
add address=X.X.190.72 comment="" disabled=no list=allow_ssh
add address=X.X.171.236/30 comment="" disabled=no list=allow_ssh
add address=X.X.171.240/30 comment="" disabled=no list=allow_ssh
add address=X.X.171.178 comment="" disabled=no list=allow_ssh
add address=X.X.190.242 comment="" disabled=no list=allow_ssh
add address=X.X.92.88/29 comment="" disabled=no list=allow_ssh
add address=X.X.92.170 comment="" disabled=no list=allow_ssh
add address=X.X.171.0/24 comment="" disabled=no list=net2
add address=X.X.209.253 comment="" disabled=yes list=allow_ssh
add address=X.X.190.162 comment="" disabled=no list=allow_ssh
add address=X.X.172.0/24 comment="" disabled=no list=net2
add address=X.X.173.0/24 comment="" disabled=no list=net2
add address=X.X.92.72/30 comment="" disabled=no list=allow_ssh
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=dummy_rule comment="SANITY CHECK FOR INPUT AND FORWARD" disabled=no
add action=jump chain=input comment="" disabled=no jump-target=sanity
add action=jump chain=forward comment="" disabled=no jump-target=sanity
add action=drop chain=sanity comment="drop connection state invalid" connection-state=invalid disabled=no
add action=drop chain=sanity comment="drop nocive ports and protocols" disabled=no protocol=tcp src-port=135-139
add action=drop chain=sanity comment="" disabled=no protocol=udp src-port=135-139
add action=drop chain=sanity comment="" disabled=no dst-port=135-139 protocol=tcp
add action=drop chain=sanity comment="" disabled=no dst-port=135-139 protocol=udp
add action=drop chain=sanity comment="" disabled=no protocol=tcp src-port=445
add action=drop chain=sanity comment="" disabled=no protocol=udp src-port=445
add action=drop chain=sanity comment="" disabled=no dst-port=445 protocol=tcp
add action=drop chain=sanity comment="" disabled=no dst-port=445 protocol=udp
add action=drop chain=sanity comment="drop rfc1918 and illegal addresses" disabled=no src-address=0.0.0.0/8
add action=drop chain=sanity comment="" disabled=no dst-address=0.0.0.0/8
add action=drop chain=sanity comment="" disabled=no src-address=10.0.0.0/8
add action=drop chain=sanity comment="" disabled=no dst-address=10.0.0.0/8
add action=drop chain=sanity comment="" disabled=no src-address=127.0.0.0/8
add action=drop chain=sanity comment="" disabled=no dst-address=127.0.0.0/8
add action=return chain=sanity comment="" disabled=no src-address=172.17.0.0/24
add action=return chain=sanity comment="" disabled=no dst-address=172.17.0.0/24
add action=return chain=sanity comment="" disabled=no src-address=172.22.0.0/16
add action=return chain=sanity comment="" disabled=no dst-address=172.22.0.0/16
add action=return chain=sanity comment="" disabled=no src-address=172.25.0.0/24
add action=return chain=sanity comment="" disabled=no dst-address=172.25.0.0/24
add action=drop chain=sanity comment="" disabled=no src-address=172.16.0.0/12
add action=drop chain=sanity comment="" disabled=no dst-address=172.16.0.0/12
add action=drop chain=sanity comment="" disabled=no src-address=192.168.0.0/16
add action=drop chain=sanity comment="" disabled=no dst-address=192.168.0.0/16
add action=drop chain=sanity comment="" disabled=no src-address=169.254.0.0/16
add action=drop chain=sanity comment="" disabled=no dst-address=169.254.0.0/16
add action=drop chain=sanity comment="" disabled=no src-address=255.255.255.255
add action=drop chain=sanity comment="" disabled=no dst-address=255.255.255.255
add action=accept chain=sanity comment="allow ssh for some customers" disabled=no dst-address-list=allow_ssh dst-port=22 protocol=tcp
add action=accept chain=sanity comment="" disabled=no dst-port=22 protocol=tcp src-address-list=allow_ssh
add action=drop chain=sanity comment="drop extern access for ssh" disabled=no dst-port=22 in-interface=Net1 protocol=tcp
add action=drop chain=sanity comment="" disabled=no dst-port=22 in-interface=Net2 protocol=tcp
add action=accept chain=sanity comment="" disabled=no dst-address=X.X.209.253 dst-port=10025 protocol=tcp src-address=X.X.190.248/29
add action=drop chain=sanity comment="" disabled=no dst-address=X.X.209.253 dst-port=10025 protocol=tcp
add action=passthrough chain=dummy_rule comment="NET1 NET2 ROUTING AND FORWARD CONTROL" disabled=no
add action=jump chain=forward comment="" disabled=no in-interface=Net1 jump-target=toknown
add action=jump chain=forward comment="" disabled=no in-interface=Net2 jump-target=toknown
add action=jump chain=forward comment="" disabled=no jump-target=fromknown out-interface=Net1
add action=jump chain=forward comment="" disabled=no jump-target=fromknown out-interface=Net2
add action=return chain=toknown comment="" disabled=no dst-address-list=net1
add action=return chain=toknown comment="" disabled=no dst-address-list=net2
add action=drop chain=toknown comment="" disabled=no
add action=return chain=fromknown comment="" disabled=no dst-address-list=lp1 src-address-list=net1
add action=return chain=fromknown comment="" disabled=no dst-address-list=lp1 src-address-list=net2
add action=return chain=fromknown comment="" disabled=no dst-address-list=lp2 src-address-list=net1
add action=return chain=fromknown comment="" disabled=no dst-address-list=lp2 src-address-list=net2
add action=drop chain=fromknown comment="" disabled=no dst-address-list=net1 src-address-list=net1
add action=drop chain=fromknown comment="" disabled=no dst-address-list=net2 src-address-list=net1
add action=drop chain=fromknown comment="" disabled=no dst-address-list=net1 src-address-list=net2
add action=drop chain=fromknown comment="" disabled=no dst-address-list=net2 src-address-list=net2
add action=return chain=fromknown comment="" disabled=no src-address-list=net1
add action=return chain=fromknown comment="" disabled=no src-address-list=net2
/ip firewall mangle
add action=jump chain=prerouting comment="" disabled=no jump-target=routes src-address-list=net1
add action=jump chain=prerouting comment="" disabled=no jump-target=routes src-address-list=net2
add action=return chain=routes comment="" disabled=no dst-address=172.22.0.0/16 in-interface=Services
add action=return chain=routes comment="" disabled=no dst-address=172.25.0.0/24 in-interface=Services
add action=return chain=routes comment="" disabled=no dst-address=172.17.0.0/24 in-interface=Services
add action=return chain=routes comment="" disabled=no dst-address-list=net1 src-address-list=net2
add action=return chain=routes comment="" disabled=no dst-address-list=net2 src-address-list=net1
add action=return chain=routes comment="" disabled=no dst-address-list=net1 src-address-list=net1
add action=return chain=routes comment="" disabled=no dst-address-list=net2 src-address-list=net2
add action=mark-routing chain=routes comment="" disabled=no new-routing-mark=to_net1 passthrough=yes src-address-list=net1
add action=mark-routing chain=routes comment="" disabled=no new-routing-mark=to_net2 passthrough=yes src-address-list=net2
add action=mark-routing chain=output comment="regras para responder corretamente trace externo" disabled=no new-routing-mark=to_net1 \
out-interface=Net1 passthrough=no src-address=X.X.237.30
add action=mark-routing chain=output comment="" disabled=no new-routing-mark=to_net2 out-interface=Net2 passthrough=no src-address=\
X.X.145.6
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.190.251 dst-port=1812 log-prefix="" protocol=udp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.190.251 dst-port=1812 protocol=udp to-addresses=X.X.209.254 \
to-ports=1812
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.190.251 dst-port=1813 log-prefix="" protocol=udp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.190.251 dst-port=1813 protocol=udp to-addresses=X.X.209.254 \
to-ports=1813
add action=log chain=srcnat comment="GBsnmp do master (cacti\?)" disabled=yes dst-address=172.22.0.0/16 log-prefix="" src-address=\
X.X.190.251
add action=src-nat chain=srcnat comment="GBsnmp do master (cacti\?)" disabled=no dst-address=172.22.0.0/16 src-address=X.X.190.251 \
to-addresses=172.22.0.183
add action=log chain=srcnat comment="" disabled=yes dst-address-list=net1 dst-port=161 log-prefix="" protocol=udp src-address=\
X.X.190.251
add action=src-nat chain=srcnat comment="" disabled=no dst-address-list=net1 dst-port=161 protocol=udp src-address=X.X.190.251 \
to-addresses=X.X.126.5
add action=log chain=srcnat comment="" disabled=yes dst-address-list=net2 dst-port=161 log-prefix="" protocol=udp src-address=\
X.X.190.251
add action=src-nat chain=srcnat comment="" disabled=no dst-address-list=net2 dst-port=161 protocol=udp src-address=X.X.190.251 \
add action=log chain=srcnat comment="" disabled=yes dst-address=172.22.0.0/16 log-prefix="" src-address=X.X.190.252
add action=src-nat chain=srcnat comment="" disabled=no dst-address=172.22.0.0/16 src-address=X.X.190.252 to-addresses=172.22.0.23
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.126.23 log-prefix=""
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.126.23 to-addresses=X.X.190.252
add action=log chain=dstnat comment="" disabled=yes dst-address=172.22.0.23 log-prefix=""
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=172.22.0.23 to-addresses=X.X.190.252
add action=log chain=srcnat comment="GBsnmp NET1" disabled=yes dst-address-list=net1 dst-port=161 log-prefix="" protocol=udp src-address=\
X.X.190.252
add action=src-nat chain=srcnat comment="GBsnmp NET1" disabled=no dst-address-list=net1 dst-port=161 protocol=udp src-address=\
X.X.190.252 to-addresses=X.X.126.23
add action=log chain=srcnat comment="GBsnmp NET2" disabled=yes dst-address-list=net2 dst-port=161 log-prefix="" protocol=udp src-address=\
X.X.190.252
add action=src-nat chain=srcnat comment="GBsnmp NET2" disabled=no dst-address-list=net2 dst-port=161 protocol=udp src-address=\
add action=log chain=srcnat comment="" disabled=yes dst-address=172.25.0.32/30 log-prefix="" src-address=X.X.190.252
add action=src-nat chain=srcnat comment="" disabled=no dst-address=172.25.0.32/30 src-address=X.X.190.252 to-addresses=172.22.0.23
add action=log chain=srcnat comment="" disabled=yes dst-address=172.25.0.184/29 log-prefix="" src-address=X.X.190.252
add action=src-nat chain=srcnat comment="" disabled=no dst-address=172.25.0.184/29 src-address=X.X.190.252 to-addresses=172.25.0.185
add action=log chain=srcnat comment="" disabled=yes dst-address=172.25.0.0/24 log-prefix="" src-address=X.X.190.252
add action=src-nat chain=srcnat comment="" disabled=no dst-address=172.25.0.0/24 src-address=X.X.190.252 to-addresses=X.X.126.23
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.190.251 dst-port=25 log-prefix="" protocol=tcp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.190.251 dst-port=25 protocol=tcp to-addresses=X.X.209.253 \
to-ports=25
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.190.250 dst-port=25 log-prefix="" protocol=tcp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.190.250 dst-port=25 protocol=tcp to-addresses=X.X.209.253 \
to-ports=25
add action=log chain=dstnat comment="" disabled=yes dst-address=172.22.0.4 dst-port=25 log-prefix="" protocol=tcp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=172.22.0.4 dst-port=25 protocol=tcp to-addresses=X.X.209.253 \
to-ports=25
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.126.4 dst-port=25 log-prefix="" protocol=tcp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.126.4 dst-port=25 protocol=tcp to-addresses=X.X.209.253 \
to-ports=25
add action=log chain=dstnat comment="" disabled=yes dst-address=X.X.126.5 dst-port=25 log-prefix="" protocol=tcp
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.126.5 dst-port=25 protocol=tcp to-addresses=X.X.209.253 \
to-ports=25
add action=add-src-to-address-list address-list=remanejar address-list-timeout=0s chain=dstnat comment="" disabled=yes dst-address=\
X.X.126.4
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.126.4 to-addresses=X.X.190.250
X.X.126.5
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=X.X.126.5 to-addresses=X.X.190.251
add action=log chain=dstnat comment="" disabled=yes dst-address=172.22.0.4 log-prefix=""
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=172.22.0.4 to-addresses=X.X.190.250
add action=log chain=dstnat comment="nat TecSys COPS" disabled=yes dst-address=X.X.126.105 log-prefix=""
add action=dst-nat chain=dstnat comment="nat TecSys COPS" disabled=no dst-address=X.X.126.105 to-addresses=X.X.171.74
add action=dst-nat chain=dstnat comment="Contingencia DNS" disabled=yes dst-port=53 in-interface=Local protocol=udp to-addresses=\
X.X.209.254 to-ports=53
add action=dst-nat chain=dstnat comment="" disabled=yes dst-port=53 in-interface=Local protocol=tcp to-addresses=X.X.209.254 to-ports=53
/ip firewall service-port
set ftp disabled=yes ports=21
set tftp disabled=yes ports=69
set irc disabled=yes ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061
set pptp disabled=yes
/ip hotspot service-port
set ftp disabled=no ports=21
/ip neighbor discovery
set Services discover=yes
set Net1 discover=no
set Net2 discover=no
set Local discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 \
serialize-connections=no src-address=0.0.0.0
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=X.X.237.29 routing-mark=to_net1 scope=30 \
target-scope=10
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=X.X.145.5 routing-mark=to_net2 scope=30 \
target-scope=10
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=X.X.237.29,X.X.145.5 scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=yes port=23
set ftp address=0.0.0.0/0 disabled=yes port=21
set www address=X.X.126.3/32 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=yes port=2200
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set Services queue=ethernet-default
set Net1 queue=ethernet-default
set Net2 queue=ethernet-default
set Local queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing ospf interface
add authentication=none authentication-key="" authentication-key-id=1 comment="" cost=10 dead-interval=40s disabled=no hello-interval=10s \
instance-id=0 interface=Local network-type=broadcast passive=no priority=2 retransmit-interval=5s transmit-delay=1s
/routing ospf network
add area=backbone comment="" disabled=no network=X.X.126.0/25
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 \
redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m \
update-timer=30s
/store
add comment="" disabled=no disk=sata1 name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=America/Sao_Paulo
/system clock manual
set dst-delta=+01:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/2025 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
set [ find vcno=1 ] disabled=no term=linux
set [ find vcno=2 ] disabled=no term=linux
set [ find vcno=3 ] disabled=no term=linux
set [ find vcno=4 ] disabled=no term=linux
set [ find vcno=5 ] disabled=no term=linux
set [ find vcno=6 ] disabled=no term=linux
set [ find vcno=7 ] disabled=no term=linux
set [ find vcno=8 ] disabled=no term=linux
/system console screen
set line-count=25
/system hardware
set multi-cpu=yes
/system health
set state-after-reboot=enabled
/system identity
set name=GBROUTER
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
add action=remote disabled=no prefix=GBROUTER topics=info
add action=remote disabled=no prefix=GBROUTER topics=error
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=200.189.40.8 secondary-ntp=200.160.0.8
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system scheduler
add comment="" disabled=no interval=1d name=backup on-event=backup policy=read,write,test start-date=jan/01/1970 start-time=00:00:00
/system script
add name=backup policy=ftp,reboot,read,write,policy,test,winbox,password,sniff source=":log info \"Iniciando procedimento de backup por e-ma\
il...\"\r\
\n/export file=everything\r\
\n/tool e-mail send from=backup@gbm.srv.br to=backup@gbm.srv.br server=X.X.209.253 subject=([/system identity get name] . \" \" . [/s\
ystem clock get date] . \" \" . [/system clock get time] . \" SYS_BKP\") body=(\"Backup geral deste sistema...\") file=everything.rsc\r\
\n:log info \"Backup por e-mail realizado com sucesso...\"\r\
\n"
add name=daily-conficker-list policy=ftp,reboot,read,write,policy,test,winbox,password,sniff source=":local date [/system clock get date]\r\
\n:local month [:pick \$date 0 3]\r\
\n:local day [:pick \$date 4 6]\r\
\n:local year [:pick \$date 7 11]\r\
\n\r\
\n#set month to numerical value\r\
\n:if ([\$month] = \"jan\") do={ :set month \"01\" }\r\
\n:if ([\$month] = \"feb\") do={ :set month \"02\" }\r\
\n:if ([\$month] = \"mar\") do={ :set month \"03\" }\r\
\n:if ([\$month] = \"apr\") do={ :set month \"04\" }\r\
\n:if ([\$month] = \"may\") do={ :set month \"05\" }\r\
\n:if ([\$month] = \"jun\") do={ :set month \"06\" }\r\
\n:if ([\$month] = \"jul\") do={ :set month \"07\" }\r\
\n:if ([\$month] = \"aug\") do={ :set month \"08\" }\r\
\n:if ([\$month] = \"sep\") do={ :set month \"09\" }\r\
\n:if ([\$month] = \"oct\") do={ :set month \"10\" }\r\
\n:if ([\$month] = \"nov\") do={ :set month \"11\" }\r\
\n:if ([\$month] = \"dec\") do={ :set month \"12\" }\r\
\n\r\
\n#download current days domain list\r\
\n/tool fetch address=www.epicwinrar.com host=www.epicwinrar.com mode=http src-path=\"conficker/\$month-\$day-\$year.txt\"\r\
\n:log info \"Download Complete\"\r\
\n:delay 2\r\
\n\r\
\n#check to ensure todays file exists before deleting yesterdays list\r\
\n:log info \"Begining Address List Modification\"\r\
\n:if ( [/file get [/file find name=\"\$month-\$day-\$year.txt\"] size] > 0 ) do={\r\
\n\r\
\n /ip firewall address-list remove [/ip firewall address-list find list=daily-conficker]\r\
\n\r\
\n :local content [/file get [/file find name=\"\$month-\$day-\$year.txt\"] contents] ;\r\
\n :local contentLen [ :len \$content ] ;\r\
\n\r\
\n :local lineEnd 0;\r\
\n :local line \"\";\r\
\n :local lastEnd 0;\r\
\n\r\
\n :do {\r\
\n :set lineEnd [:find \$content \"\\n\" \$lastEnd ] ;\r\
\n :set line [:pick \$content \$lastEnd \$lineEnd] ;\r\
\n :set lastEnd ( \$lineEnd + 1 ) ;\r\
\n\r\
\n#resolve each new line and add to the address list daily-conficker. updated to list domain as comment\r\
\n :if ( [:pick \$line 0 1] != \"\\n\" ) do={\r\
\n :local entry [:pick \$line 0 (\$lineEnd ) ]\r\
\n :if ( [:len \$entry ] > 0 ) do={\r\
\n\t :local listip [:resolve \"\$entry\"]\r\
\n :if (\$listip != \"failure\" ) do={\r\
\n /ip firewall address-list add list=daily-conficker address=\$listip comment=\$entry\r\
\n :log info \"\$listip\"\r\
\n }\r\
\n } \r\
\n }\r\
\n } while (\$lineEnd < \$contentLen)\r\
\n}\r\
\n:log info \"Address List Modification Complete\"\r\
\n#cleaning up\r\
\n/file remove \"\$month-\$day-\$year.txt\"\r\
\n"
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=no enabled=yes max-sessions=10
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=X.X.126.3/32 disabled=no interface=all store-on-disk=no
/tool graphing queue
add allow-address=X.X.126.3/32 allow-target=no disabled=no simple-queue=all store-on-disk=no
/tool graphing resource
add allow-address=X.X.126.3/32 disabled=no store-on-disk=no
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames \
filter-stream=yes interface=Net2 memory-limit=10 memory-scroll=no only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
janisk
Wed Feb 17, 2010 12:27 pm
just a note - just input relevant parts, please omit parts that are not configured. it would make export more readable. Now it just looks huge :)
on the topic - I would suggest you to do the following:
first - accept already know connections and stuff, that is connection-state=related and connection-state=established that will accept 90% of packets, so their primary packets already have passed through your firewall and you accepted them. That can be done simply there where it is now. There is no point in checking already accepted connection packets.
then you go and check packets with connection state new, weather it is UDP stream first packet or TCP it is all the same, just run through the rule lists where what should go.
With this configuration i do not know hardware that could pass 1GBit traffic through with medium sized packets - such hardware simply, just does not exist.
Ozelo
Wed Feb 17, 2010 9:03 pm
Good enough! :) Could save about eight percent on that DELL Opteron. It was 44%, now its 38%. There are about 100kpps summing all the interfaces tx/rx packets rate. Conntrack show about 150k entries over ten thousand IP addresses. So, its not a flawed test. RB1000 just don't fit... ;)
janisk
Thu Feb 18, 2010 2:06 pm
well, it is not just drop in cpu usage, it is huge drop in latency in your network.
Just keep reading forums and wiki about best practices and how what should be done to make it even more optimal.
firewall optimization is pretty simple, check rules that match post of the packets, move them higher, so they match faster. All that is done to get latency down, and less latency usually means also less CPU cycles used per packet, less CPU usage.
You can check through the configuration to recognize choke points.
changeip
Thu Feb 18, 2010 8:53 pm
disable the logging rules and see if that helps.
gmidia
Thu Feb 18, 2010 10:30 pm
from the experiences indicated here i guess the Duo 2 core machine with RouterOS has an better performance than RB1000 but bit more costly. Mikrotik what is it that you are coming up with that would work better than than a duo 2 core or quad core system if any
missinlnk
Fri Feb 19, 2010 5:40 pm
Actually, the lesson I got is that inefficient rules will bring down any router/firewall from any company. Throwing extra money behind faster hardware won't fix the problem, it'll just mask it. You'll see this issue with Cisco and Juniper just as much as you'll see it with Mikrotik.
I'm happy to see an update to the RB1000U. But it won't fix the problems listed in this thread.
gmidia
Sat Feb 20, 2010 12:40 pm
why did RB1000 have to reach EOL if it is a Good/Perfect Router OS product? Mikrotik???
normis
Mon Feb 22, 2010 10:31 am
RB1000 is still available. Only RB1000U in rackmount case is no longer available. Compact case edition is still in stock.
missinlnk
Mon Feb 22, 2010 5:20 pm
And there are still retailers who have the RB1000U in stock.
roc-noc.com
Forum Veteran
Forum Veteran
Tue Feb 23, 2010 5:20 am
Yes. I know of at least one distributor with stock. :)
Tom
missinlnk
Tue Feb 23, 2010 5:53 pm
Awesome, that means I know of two distributors with them in stock! :D
Scott Long
Technical Support Supervisor
WISP-Router, Inc.
http://www.wisp-router.com
Users browsing this forum: No registered users and 23 guests
