Yeah, I've seen the NZNOG presentation (probably via your link) as well as the papers by Vyatta/Intel and Jesper Dangaard and whilst there may still be some work to do to get more performance out of the Intel drivers, you are already getting up to 3.5Mpps on a modern Intel quad core chip and 10Gbps bi-direction full duplex at 1k packets.Hrmm, I think going to 10gigabit interfaces is a bit ambitious for the already very busy Mikrotik devs. I think you may be referring to the NZNOG presentation on 10gig routing on linux I linked to in one of my other posts.
On a side note, the new Allied Telesis x600 and x900 switches run Linux and manage to route up to 160gigabit. I am guessing with some sort of hardware offload.
Very true, case in point would be the three different PIM slots used by Juniperbut I think that any custom modules/slots should take future bandwidth requirements into account from day one.
Yeah exactly, and Cisco are no better...Very true, case in point would be the three different PIM slots used by Juniperbut I think that any custom modules/slots should take future bandwidth requirements into account from day one.
I'm sorry but who cares about the price if the box is just not powerful enough?But you will definitely like the price
We combine Licensed Gear with MT. Licensed Gear has a fiber connector.But you will definitely like the price
We are also working on a more powerful device, but it's not ready yet. Send your SFP suggestions with usage examples and requirements.
this product was created based on demand. apparently in this regard, your opinion is different from most. but, as I said, we will also try to make something for you.I'm sorry but who cares about the price if the box is just not powerful enough?
It's not like i can stack three of those boxes so they have enough throughput and processing power.
I think nobody would have had a problem with a RB1100 that costs 600 USD but has appropriate cpu power on board.
What is the purpose of the bypass switch on RB1100?
Can you give example of where you would use such product? What would be your basic requirements if we made such router? Can you list a few features you personally need?We need powerful router than RB1000 also need SFP ports.[2]
Thanks. I could use this feature on all traffic shaping bridges. Will this feature will be available on lower end models?What is the purpose of the bypass switch on RB1100?
http://www.google.com/search?hl=en&clie ... =&aql=&oq=
I just say this cause I listen much about about this. About need a powerful router than RB1000.Can you give example of where you would use such product? What would be your basic requirements if we made such router? Can you list a few features you personally need?We need powerful router than RB1000 also need SFP ports.[2]
do you asking that from me?Do you have any exact hardware requirements?
no, and that's a reason I build them for last 10 years myself from SFF PC's and switches. Cisco and probably others big brands have suitable products, but these is usually not for that market and is way too expensive. I think that this is another point for MT for making those. You will have 100% market share instantly.Is there a similar device out there that you like?
Yes, I have seen some distributors with 390$ price. A very good deal!$400 sounds like a great price point for a 1U RouterBOARD and RouterOS Level 6 License.
There is the CPE side with something like the Cisco ME3400-2CS (2 dual-purpose ports (10/100/1000 and SFP) and 2 SFP uplinks) or even better more like the Juniper SRX210, which has 2xgigabit and 6x100 megabit ports with an optional SFP slot, i am comparing this model with RB750G/RB450G/RB1100 right now for business CPE deployments as they both have VPLS and comparable performance.Do you have any exact hardware requirements? Is there a similar device out there that you like?
hm..it's my understanding that traffic from ports 1-5 to ports 6-10 11 12 13 and is limited to .25-1GB as it has to be CPU switched. Please correct me if I'm wrong.Laurinkus, the throughput is from one port to other port, not total!
Routers are for routing and switches are for swithing. RB1100 is a router and according to benchmark it has routing capacity of ~2Gbps. Hence, 2xGigE bonded interfaces should be enough for this purpose.hm..it's my understanding that traffic from ports 1-5 to ports 6-10 11 12 13 and is limited to .25-1GB as it has to be CPU switched. Please correct me if I'm wrong.
My first impression is that this device should be quite expensive ($4k and more) while RB1100 expected price is something around $400-$500. Why to pay more when you can pay less ?Hi all,
For all those asking for SFPs (including myself), I just bumped into this platform, looks ideal for RouterOS...
http://www.advantech.com/products/FWA-6 ... SQLLN.aspx
I have access to a couple of these boxes, I'll try to build a test RouterOS setup with it and see how it goes.
Because you getWhy to pay more when you can pay less ?
That is an interesting box. How much is it?Hi all,
and how did you come up with these numbers ?and is limited to .25-1GB as it has to be CPU switched
\o/On april 1st, anything is possible
Which appears to be in direct contradiction to http://forum.mikrotik.com/viewtopic.php?f=3&t=41533...Although the SODIMM slot and memory options are the same as the RB1000, not all of my SODIMMs worked for RAM expansion. Some 2GB modules that worked fine with the RB1000 prevent the RB1100 from posting.
With correct data please!I guess it's time to update the data sheet Normis.
It is not a pretty picture. At this point I don't have confidence in any RAM other than the stock 512MB modules.Which appears to be in direct contradiction to http://forum.mikrotik.com/viewtopic.php?f=3&t=41533...Although the SODIMM slot and memory options are the same as the RB1000, not all of my SODIMMs worked for RAM expansion. Some 2GB modules that worked fine with the RB1000 prevent the RB1100 from posting.
P.S. Tom, is there any chance of you disclosing which DIMMs worked in the RB1100 and which didn't ?
Regards,
Terry Froy
Spilsby Internet Solutions
I bumped it during the 4.9 upgrade and the loose power cord caused a reboot.honzam, we are working on it, it will be available today or Monday.
roc-noc.com what was the reason for the reinstall?
So why not make a second version that includes the SFP ports a lot of forum members are asking for and sell it at a higher price, just as the tranditional router and switch companies like Cisco, Juniper, Foundry/Brocade, Extreme and Dell do?maxrate, great that you received new RouterBOARDs. SFP port would not allow the price, RB1100 has sold currently.
Ethernet to fiber converters doesn't cost much today.Awesome, I received 3 Routerboard 1100's today! I wish they had SFP ports
But they are bulky and external. It's easy to knock them if you are using the little standalone ones that take a 5v DC power supply brick or whatever so you end up accidentally disconnecting the fibre/copper/power from them. They are also another potential point of failure.Ethernet to fiber converters doesn't cost much today.Awesome, I received 3 Routerboard 1100's today! I wish they had SFP ports
And we need these converters with extended Temperature Range and GigabitBut they are bulky and external. It's easy to knock them if you are using the little standalone ones that take a 5v DC power supply brick or whatever so you end up accidentally disconnecting the fibre/copper/power from them. They are also another potential point of failure.Ethernet to fiber converters doesn't cost much today.Awesome, I received 3 Routerboard 1100's today! I wish they had SFP ports
Chassis based converts solve this, but are more expensive and take up much more space - not great if you only need a few fibre ports and the rest as copper.
With SFP ports on the router, you can always put a 1000baseT module in and terminate copper directly on the router for the ports you don't need as fibre. Yes it costs more, but I haven't seen anyone here saying that they want SFP ports at RB1100 prices.
Maybe GBIC would be cheaper?maxrate, great that you received new RouterBOARDs. SFP port would not allow the price, RB1100 has sold currently.
You can use a switch, but then you either have to LACP multiple ports or put up with having a single gigabit port as a bottleneck. You also still have another single point of failure - the switch.It was just a suggestion to use a media converter since it's the only option right now. Can't you use a switch, why do you need SFP in your router? I've done thousands of installations, and I've never seen a server room without a switch with SFP ports. For some installations, I use cheap $500 D-Link DGS-1224TP switches. This switch has 24 10/100/1000BASE-T PoE, and four SFP ports. It's also manageable and has many features like QoS VLAN etc.
Really? I think the bottleneck is the RB1100, not the switch. You can bond several ports, and I doubt RB1100 can handle this traffic.You can use a switch, but then you either have to LACP multiple ports or put up with having a single gigabit port as a bottleneck.
If you have two devices, either of which is a single point of failure, then the probability of the failure of either (which will cause a complete outage and thus a failure of the "system") is greatly increased compared to if you have a single device which is a single point of failure. Basic statistics.Really? I think the bottleneck is the RB1100, not the switch. You can bond several ports, and I doubt RB1100 can handle this traffic.You can use a switch, but then you either have to LACP multiple ports or put up with having a single gigabit port as a bottleneck.
Well if I have 2x1Gbps fibre ports that need to talk to each via the router (routed VLANs etc) than they are sharing a single 1Gbps link from the router to the switch. Apparently the RB1100 can do about 2-3Gbps.
Have you heard the definition "single point of failure"? If one unit fail, the entire network will fail.
But you aren't talking about redundancy in this case, you are talking about using a switch as a fibre converter. That means you now have two units doing the same overall job (terminating fibre connections and routing the traffic on them) rather than a single unit in the case of having a RouterBOARD with SFP ports. Now the failure of either the switch or the RouterBOARD will cause a failure, which is statistically more likely than the failure of just one integrated device doing a job.A single unit is worse than as a system with many units, the failure of one unit will disable the entire system. If a single unit fail, then you also need to reconfigure everything.
Of experience, I prefere to have several units than one single unit, even the efforts of more units to manage. If you have a serious business, then you should have redundance in your network, and that involves several units.
That's not going to change between an SFP in the switch or in the router though.A fiber module is also a single point of failure. If you talk about probability, a fiber module is the first thing to fail. It doesn't matter if it's in the router, or outside in a box.
Kind of missing the point, the whole reason we were discussing it was because lots of people want Mikrotik to build one so you get the single vendor support of an embedded system. There are plenty of work around, but the question was why aren't Mikrotik making the option available to their customers that clearly want it.If it's so important with a single unit, just buy a firewall appliance from Lanner or Acrosser and install RouterOS.
Actually, I don't have a need for SFP ports in the RB1100 at the moment, I was just replying to Mikrotik who in turn were replying to someone that did.If I were you, I would buy a media converter and modify my RB1100.
Like you, arguing with me when like I'm toatal against the idea. I just wanted to inform of alternatives, since there is no MikroTik routers with SFP ports at the moment (probably not for many years). I also searched the forum, and it's basicly the same person whining and moaning that he need to connect his router to STM-1 and SFP lines.Kind of missing the point, the whole reason we were discussing it was because lots of people want Mikrotik to build one so you get the single vendor support of an embedded system. There are plenty of work around, but the question was why aren't Mikrotik making the option available to their customers that clearly want it.
I think most people don't want it due to the increased price tag. I remember one guy in this forum asked if there is an Interface Card that he could use with MikroTik to be able to use his new OC-3 Line. I offered him a cheap solution to his issue, but he completely rejected it and shout out "OFF TO CISCO".Actually, I don't have a need for SFP ports in the RB1100 at the moment, I was just replying to Mikrotik who in turn were replying to someone that did.
There are 16 people in this thread alone that have said they want something like the RB1000 or RB1100 but with SFP ports... several of them have explicitly said that they do not mind paying more for a product that supports SFP modules.Like you, arguing with me when like I'm toatal against the idea. I just wanted to inform of alternatives, since there is no MikroTik routers with SFP ports at the moment (probably not for many years). I also searched the forum, and it's basicly the same person whining and moaning that he need to connect his router to STM-1 and SFP lines.Kind of missing the point, the whole reason we were discussing it was because lots of people want Mikrotik to build one so you get the single vendor support of an embedded system. There are plenty of work around, but the question was why aren't Mikrotik making the option available to their customers that clearly want it.
A RAD media converter from Giga Ethernet to STM-1/OC-3 cost around €500, and one Axiom SFP-OC3-SR-AX module to a switch cost around €150.
A Cisco 1-Port Channelized STM-1/OC-3 line card adapter cost around €32,400.00 (List Price). Then you need a Cisco router to plug in this line card adapter.
But the guy wasn't satisfied, with my answer, because he replied with "OFF TO CISCO".
As I said before, I'm not against the idea of SFP ports in Routerboard, but It's not that important that I will pay 20 times more just for one single SFP port. You can buy similar router/firewall appliances with SFP ports for around $10 000. I rather buy a bunch of other things, like several units I can quickly switch if any of them fail. Believe me, it will pay of in the long run.There are 16 people in this thread alone that have said they want something like the RB1000 or RB1100 but with SFP ports... several of them have explicitly said that they do not mind paying more for a product that supports SFP modules.
Ah, so now you're twisting my own words around, I was never talking about that. Since SFP ports doesn't exist yet on Routerboard, I was talking about alternatives. If it's true that RB1100 can't handle the traffic, then why not buy a VLAN aware switch with SFP ports and PoE? That would be the ultimate solution, and that is also what I always have done, and it's the omly option right now. Well, you can OFF TO CISCO if you prefer that.I used to have a similar opinion, why would you want SFP ports on a Mikrotik router?
Well, now I too want them. We are doing a number of CWDM projects at the moment, and having a Mikrotik router with high throughput, multiple "full speed" SFP's and a multicore CPU would be perfect for us.
By full speed, I mean each SFP/port can communicate at the full 1000mbit speed, unlike the RB1100 which is technically two switches, each one with a single uplink.
But you still can't get away from the performance and reliability problems that adding an extra physical device to a logical system brings.I've been working in the field of networing since the end of 1980, and what I've seen is that every server room is half empty. We have never had so many servers that we have today, but still all server rooms is half empty (i don't mind to have extra units).
That's due to smaller servers, and virtualization.
I really didnt mess with it that long. Just long enough to see that there was no switch option in Winbox. Maybe you can from the CLI. Just didnt get that far yet.Do you mean access by Winbox? The support for Winbox is added at 5.0beta3.
When will we see beta3?Do you mean access by Winbox? The support for Winbox is added at 5.0beta3.
What is your RouterOS version and RouterBOOT version?I have problem with RB1100,
when I put the cable from other modem/router/switch to RB1100 port 11, 12 or 13, router always stuck / every 5-10 minutes interface/ether always disconnect/down. anyone have a same problem with me?
but port 1-10 is normal!..
bug or something??
firmware: "2.27"What is your RouterOS version and RouterBOOT version?I have problem with RB1100,
bug or something??
Tom
Oh yeah, I forgot about this place. Anyway...firmware: "2.27"What is your RouterOS version and RouterBOOT version?I have problem with RB1100,
bug or something??
Tom
version: "4.10"
Mine has the standard 512MB RAM. I set the RAM clock to 533MHz and it automatically scaled up the CPU clock to 1333MHz. Multiple reboots and power-cycles and it's still there. Just running on the bench right now because of the ethernet issues.I have installed a RB1100 as a networks access control, but i have a serious problem, cpu go to 100% usage all time, i have 645 users, i have disabled connection tracking, simple queue, firewall mangle eccept global mss-change, natting, pppoe compression, all queue.... i'll must to disable entire RB1100 for get a reasonable use of cpu ?
I have also overclocked cpu to 1Ghz, can i overload memory bus to 533 Mhz ?
FR4
P.s. i prefer a most expansive but usable hardware, that a low cost unusable hardware ....
Thanks for the email reply, Tom.Oh yeah, I forgot about this place. Anyway...
Same here, 4.10/2.27 and ether11-13 issues. Ticket#2010061066000061 with MT support, waiting since 6/9/10. I can understand the wait since this now looks like a problem not specific to the unit I have.
I wonder if this is auto-MDI/X related? I think I have straight-through cables at my site, maybe x-overs will fix this?
Tom, I sent you an email. I guess this answers the question of others reporting ethernet issues.
We use PowerRouter 732 with RouterOs and 2 Gbic fiber interfaces, works like a charm.MT does not have today any product with ability to connect it directly to the fiber. That's a shame...
So, how much empty miniGBIC or SFP slot will costs? $10-20? Today, even $100 switches come with one or two of these, so they can not be more expensive than that. Well, ok, if MT will add that price to the RB1100, we all can live with that. Even better would be add-on module (PCIe) for RB800 and some other higher end models. Right now, I connect even RB750G's to backbone via converters, which is almost same size like router, require extra power outlet, and have 5V supply, what will die on every 10th power surge.
Btw, I, personally hate media converters. They are most unreliable things I have ever seen. And I have hundreds of them ...
PS: SFP can easily be converted to Ethernet.
to be exact it is not MirkoTik productWe use PowerRouter 732 with RouterOs and 2 Gbic fiber interfaces, works like a charm.
Suggestions:We are also working on a more powerful device, but it's not ready yet. Send your SFP suggestions with usage examples and requirements.
Did you disable the console support on the serial port first?How can I connect a APC Smart UPS to RB1100? On serial is not working.
What's new in 4.17 (2011-Mar-02 10:53):Anyone still having problems with Prts 11-13? It was working for about 10-11 days on mine after putting 5.0rc4 dated 11/9/2010 on it, then I upgraded to 5.0RC4 11/22/2010 and it started dropping link every 5 minutes again. PAradyne DSL modem, RB433AH and Dlink DES-3028.
I downgraded to the 5.0rc4 I was running and it still didnt work.. Its like it only worked for that one reboot.
