Hi guys. Just looking for a little advice on which equipment to use for a Wifi setup that is going to be used in a travel trailer/RV park.
I think I have it nailed down to either a 411AH with an R2N card, or maybe going cheaper with a 411AR.
This setup doesn't need to be high preformance, since it will probably be servicing less than 10 people, and it will only be plugged into a Canopy 900. That makes me want to go with the cheaper option (411AR), but the thing that gives me pause is the weaker radio.
I am also considering the Pac Wireless 17db 90deg antenna (no omni's, as I want to shape the signal away from the gas station next door). Is this a good choice, or do you think it's a bit much for the situation that I am describing?
I am greatful for any info that you think might help. Thanks for your time.
