• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
RB750G Port 3 to 5 slow and losing packets  Page 1 of 1
 [ 3 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
lcx
 Post subject: RB750G Port 3 to 5 slow and losing packets
PostPosted: Sat Apr 10, 2010 1:10 pm
Offline
I have folowing problem with a RB750G with routerOS 4.6
If I switch connect a device to port 3,4 or 5 I have packet loss and very very slow connections.
If I connect it to the switch, which is connected on port 2 then everything is fine.
Here is my setup:
Code:
 /ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   ;;; default configuration
     192.168.88.1/24    192.168.88.0    192.168.88.255  ether2-local-master
 1 D 78.92.144.146/22   78.92.144.0     78.92.147.255   ether1-gateway
Code:
 /interface print
 #     NAME                                        TYPE             MTU   L2MTU
 0  R  ether1-gateway                              ether            1500  1524
 1  R  ether2-local-master                         ether            1500  1524
 2     ether3-local-slave                          ether            1500  1524
 3     ether4-local-slave                          ether            1500  1524
 4     ether5-local-slave                          ether            1500  1524
 5  R  l2tp-out1                                   l2tp-out         1460
 6  X  OVPN-Client                                 ovpn-out
Ping from when a device is connected to port 3
Code:
ping 192.168.88.1
PING 192.168.88.1 (192.168.88.1): 56 data bytes
64 bytes from 192.168.88.1: icmp_seq=0 ttl=64 time=1.830 ms
64 bytes from 192.168.88.1: icmp_seq=1 ttl=64 time=39.734 ms
64 bytes from 192.168.88.1: icmp_seq=2 ttl=64 time=5.972 ms
64 bytes from 192.168.88.1: icmp_seq=3 ttl=64 time=29.474 ms
64 bytes from 192.168.88.1: icmp_seq=4 ttl=64 time=39.111 ms
64 bytes from 192.168.88.1: icmp_seq=5 ttl=64 time=27.244 ms
64 bytes from 192.168.88.1: icmp_seq=6 ttl=64 time=8.248 ms
64 bytes from 192.168.88.1: icmp_seq=7 ttl=64 time=8.039 ms
64 bytes from 192.168.88.1: icmp_seq=8 ttl=64 time=30.438 ms
64 bytes from 192.168.88.1: icmp_seq=9 ttl=64 time=332.505 ms
Request timeout for icmp_seq 10
64 bytes from 192.168.88.1: icmp_seq=10 ttl=64 time=1832.552 ms
64 bytes from 192.168.88.1: icmp_seq=11 ttl=64 time=856.480 ms
64 bytes from 192.168.88.1: icmp_seq=12 ttl=64 time=1.424 ms
64 bytes from 192.168.88.1: icmp_seq=13 ttl=64 time=1407.067 ms
64 bytes from 192.168.88.1: icmp_seq=14 ttl=64 time=577.481 ms
64 bytes from 192.168.88.1: icmp_seq=15 ttl=64 time=79.095 ms
64 bytes from 192.168.88.1: icmp_seq=16 ttl=64 time=16.764 ms
64 bytes from 192.168.88.1: icmp_seq=17 ttl=64 time=14.521 ms
64 bytes from 192.168.88.1: icmp_seq=18 ttl=64 time=44.496 ms
64 bytes from 192.168.88.1: icmp_seq=19 ttl=64 time=333.641 ms
Ping when the same device is connected to the switch on port 2
Code:
ping 192.168.88.1
64 bytes from 192.168.88.1: icmp_seq=0 ttl=64 time=1.337 ms
64 bytes from 192.168.88.1: icmp_seq=1 ttl=64 time=1.173 ms
64 bytes from 192.168.88.1: icmp_seq=2 ttl=64 time=1.208 ms
64 bytes from 192.168.88.1: icmp_seq=3 ttl=64 time=1.088 ms
64 bytes from 192.168.88.1: icmp_seq=4 ttl=64 time=1.110 ms
64 bytes from 192.168.88.1: icmp_seq=5 ttl=64 time=2.349 ms
64 bytes from 192.168.88.1: icmp_seq=6 ttl=64 time=1.204 ms
64 bytes from 192.168.88.1: icmp_seq=7 ttl=64 time=1.766 ms
64 bytes from 192.168.88.1: icmp_seq=8 ttl=64 time=1.803 ms
what could be wrong here?
Top
 Profile
meno
 Post subject: Re: RB750G Port 3 to 5 slow and losing packets
PostPosted: Fri Apr 16, 2010 11:32 pm
Offline
try to use port1 and (2-5) and see if get better
Top
 Profile
hedele
PostPosted: Wed Apr 21, 2010 10:13 am
Offline
This has no effect on a RB750G, as the ethernet interfaces are connected to the same interface on the CPU.
It does help on a RB450G however. Still, I guess the problems might be some kind of configuration issue. I have never seen a RB750G where one ethernet port would produce such latencies.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 3 posts ]
Board index » Other topics » RouterBOARD hardware
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
