samuelongui
How to reset RB450G?
Thu Mar 17, 2011 12:52 am
I have try this:
unplug DC adapter.
press reset.
connect DC adapter wihout stop pressing reset
it works on RB750G, but not on RB450G. which is the correct sequence? Without Winbox of course.
fewi
Re: How to reset RB450G?
Thu Mar 17, 2011 12:56 am
http://routerboard.com/pricelist/download_file.php?file_id=143
Software Reset
It is possible to reset all software configuration by short-circuiting the reset-hole during the power-up (see
ROS reset in layout diagram). No confirmation or passwords will be asked, so use with caution. This feature
can be disabled in the “system routerboard settings” menu by switching the “enable-jumper-reset”
parameter to “no”.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
samuelongui
Thu Mar 17, 2011 1:02 am
Too difficult, I don't understand anything :?
InoX
Thu Mar 17, 2011 1:05 am
samuelongui
Thu Mar 17, 2011 1:09 am
InoX wrote:
http://wiki.mikrotik.com/wiki/Manual:Password_reset
so, I have to close the hole, plug the jack DC and it will reset, correct?
robby
Thu Mar 17, 2011 6:24 am
normis
Thu Mar 17, 2011 11:29 am
yes, correct. put some screwdriver (or anything metal) into the hole, apply power and wait until it boots.
it's much easier than netinstall, by the way
robby
Thu Mar 17, 2011 11:40 am
Ha ha ha.. true Normis, for most people, but for me, it's easier using netinstall, maybe because I am quite used to it.
heviejob
Tue Feb 12, 2013 12:07 pm
How do I get a RB450g into netinstall mode if I don't have a serial
console cable?
Cydon
Wed Mar 23, 2016 7:25 am
does it has a button that need to be pressed ? the reset jumper hole
or just simply put a metal thing in that hole ?
i've been asked to reset RB450, but when i open the case and put a needle in the reset hole, there's nothing, i thought there would be a button or something
sash7
Wed Mar 23, 2016 9:06 am
https://youtu.be/G-iIxxXcYq0
Sent from my LG-H502 using Tapatalk
Cydon
Re:
Wed Mar 23, 2016 11:00 am
too bad the office where i currently interning doesn't give an access to youtube for bandwidth reason :s
thanks for replying tho
Users browsing this forum: soonwai and 10 guests
