i can never reach 100Mbps in my setups, even at very close range < 2km, good clean area (no noise), max i get is 80mbps (oneway)TCP, 95Mbps UDP (oneway), once i have it running on both, bandwidth drops to half (about 45mbps + 45Mbps => worst on TCP).groove has 100MBps ethernet interface, so, you can saturate that, and then still have some upload left (25MBps).
Try nv2 nstreme And you Will have more speedWe have a 4 links with Groove HW. 40Mhz with Nstreme ccq 80-90% max 70mbps (50ms ping) ccq falls on 50%....personaly I expected more
And no one knows this? How to make the ap to show signal leds??????hi there, does anyone knows how to make the groove AP to show signal LEDS?,
the STA is OK...showing the singnal leds
ros 5.7
to AP.... LEDs
Type:wireless signal strenght
led1,led2,led3,led4,led5
interface:wlan1
what I`m doing wrong?
I have also tryed to Type: modem signal... but the leds than stay ON all the time regarding the signal strenght...even if I turn off the STA... the LEDs on AP will stay on in this mode... and like I said... using on Type: wireless signal strenght ... the LEDs does not lit at all.
PS: I really like the groove so far, comes with power adapter 24v 0.8Ah, poe injector and 2 plastic strips, and yes... it is more cheap than the bullet m5hp witch comes with none of those... and not to mention the runing software with is 10000000 years more advanced than the AirOS witch comes to ubiquiti... ooooo and .. the VOLTAGE MONITOR witch is WHAT every one who runs a solar site NEEDS!....not to forget the beeper witch plays mario theme on startup
Bad config or link.using NV2 = max 3mbps ccq 5% and time out
Well, probably because it is in AP mode.... What signal do you want? AP usually has several stations connected, so how does AP knows which signal to show? So it is useless feature and thus probably not available in software.And no one knows this? How to make the ap to show signal leds??????hi there, does anyone knows how to make the groove AP to show signal LEDS?,
ros 5.7
to AP.... LEDs
interface:wlan1
what did you mean bad config? Nstreme with frame policy best fit on 4000, signal -64/-64 ccq is cca 80% registration rate 100-150mbps (changing) in BT UDP test 60mbps then ccq fall on 50%.
yes any 802.11G, 2.4Ghgz or 5Ghz, ie:choose 20/40Mhz on AP device. or did you mean 802.11G ? 2,4G?
I prefer using 32dBi antennas (solid dish or 80cm satellite dish + 5GHz feeder) and use lower tx power.no, I have 3999 (advice from internet forum)
distance 3km, JIROUS JR24 vs. JIROUS JR29
can you recommend me any other frame policy?
Fresnell is not very clear but is ?Line of sight? I see other side..
because, there are currently many sites that already on turbo mode and all of their clients are turbo enabled (not supporting 802.11n).why not to use 802.11n? more data at same channel width.
You should run a throughput test between 2 units that are connected to each end of your groove-groove link. This way the CPU of these external units produce the data and the groove's only have to pass the traffic. Now you can really 'see' how much your link can carry.yeah, after align antenna I have -53/-53 ccq + - 100%..
BT test groove-groove 97mbps Receive / 97mbps send....of coutre Nstreme best fit 3999 .
Now I have a question, can groove generate more data? over 97mbps? because it stops on 97mbps....ccq is still 100%, ping 1-10ms where is the problem?
nice, have you tried tcp?yeah, after align antenna I have -53/-53 ccq + - 100%..
It can, you only have to set both as legacy 802.11a device. Ubnt airmax or MT-NV2 is both propietary TDMA which means in that mode they cannot.I found this site, the groove can not communicate with the bullet 5M.
I will regret if I want to gradually switch to the groove.
A wonderful device.
http://www.wirelessinfo.be/Link-testen/ ... /index.htm
