temuri426
can't reset rb1200 using reset button
Mon Aug 01, 2011 11:37 am
hello
we've bought three rb 1200 and i'm unable to reset username and passwords from reset button. i pressed on int while power cycling , but no results..
i knew about other solution opening the box hold screwdriver in reset hole, but i dont need eny time to open almost 15 screws,,
is there any simple solution using reset button?
thanks
normis
Re: can't reset rb1200 using reset button
Mon Aug 01, 2011 11:40 am
sorry but the button on RB1200 only loads the primary boot loader, to do reset, you must open the case. this is explained in the guide:
http://routerboard.com/pricelist/downlo ... ile_id=308
temuri426
Mon Aug 01, 2011 3:00 pm
thanks normis
But if i can reset all configuration using reset button in rb750, so why it is not posible to do the same in rb1200.. ?
normis
Mon Aug 01, 2011 3:10 pm
the behaviors are different in our rackmount/professional series and in our plastic case low cost series. we will move to the more convenient system in the future.
temuri426
Mon Aug 01, 2011 3:15 pm
thanks..
Users browsing this forum: florentrivoire, Google [Bot], kenyloveg and 10 guests
