felipesantos
Restart RB1200 every day, aleatory
Mon Sep 19, 2011 4:04 am
RB 1200
Traffic - 35MB
Version: 5.6 after 5.7 was drawn
The RouterBoard randomly reboot during the day. Even with lower traffic it restarts. Average temperature 55 degrees. And both have the same problem RouterBoard. I'm worried because I still have two more of them here. Saver if I would like to have more people having the same problem. And how to solve. I have already sent the file to the support. More time someone has already managed to solve the problem.
Felipe R. Santos
Temperature
Temperature System
Temperature CPU
Cpu
franco
Re: Restart RB1200 every day, aleatory
Mon Sep 19, 2011 12:04 pm
I also have this problem with two RB 600 Board.
Sporadic reboots are on the agenda.
One routerboard have the Version 5.6 and the other 5.7.
Franco
franco
Mon Sep 19, 2011 12:13 pm
right now a RB 433 AH with RouterOS 5.6 has rebooted.
In the LOG you can see the follow message:
router was rebooted without proper shutdown (cause1)
with the Version 4.xx i never have this problems.
I hope MT FIX this problem.
Franco
fildan70
Wed Sep 28, 2011 11:07 am
Hello everyone.
My RB1200 has problems after a scheduled reboot (swicth off).
After the reboot, the ethernet LEDs number 1 (connected to a cisco router) are turned off. Controls "watchdog" and NetWatch containing scritp running reboot, have no effect.
Given the problems mentioned on this thread at this point I can not understand if the problem is hw or sw type. I do not know what to do. Change rb1200 with another router or wait for new firmware, or send my 1200 for repair hoping it's a hardware problem.
honzam
Wed Oct 12, 2011 2:26 pm
How did you solve this problem? Firmware latest. ROS 5.7 or a test build 5.8 and still have problems with reboot
LAN, FTTx, Wireless. ISP operator based on ROS. If the post helped, give Karma...
hapi
Tue Oct 18, 2011 2:13 am
more people from the Czech Republic has problems with spontaneous reboots. Devices are loaded around 80Mbit. Then there is a random restarts.
jordiv
Thu Oct 20, 2011 6:00 pm
Hi there,
I own two RB1200 that just put them on production and they happen to have that problems. Every 5-30 minutes they reboot aleatory.
Just sent the support.rif to the vendor and to the Mikrotik support.
Jordi.
honzam
Thu Oct 27, 2011 5:37 pm
Any changes for rb1200 in routerboot 2.37 ?
We also have a problem with rebooting - Ticket#2011092166000416
ro000917
Fri Oct 28, 2011 12:27 am
Im testing firmware 2.37, and maybe OK.
See http://ispforum.cz/viewtopic.php?f=7&t=8033&start=75
normis
Fri Oct 28, 2011 7:43 am
Upgrade RouterBoot firmware to v2.37
http://routerboard.com/RB1200
Upload the firmware file to router and upgrade with command:
/system routerboard upgrade
Reboot router after this command is entered.
Please send us new supout file if you still experience rebooting on RB1200.
miahac
Long time Member
Long time Member
Fri Oct 28, 2011 4:27 pm
fildan70 wrote:
Hello everyone.
I have had the EXACT same problem. It was every other day, now every other week. I was connected to a Cisco ASA on one side and Cisco router on the other. Some times both ports went dead. But I could get to the other ports. Upgrading from 5.2 to 5.6 seemed to reduce this occurrence, but it still happens.
Network Administrator
Kansas Hosting and Wichita Data Centers
miahac
Long time Member
Long time Member
Fri Oct 28, 2011 6:45 pm
Sorry did not see this. I will do it.
helectro
Mon Oct 31, 2011 3:29 am
routerboard: yes
model: 433UAH
serial-number: 1E44019DB2E6
current-firmware: 2.29
upgrade-firmware: 2.29
Same Problem reboot cause 1 every 2 hour aprox!!
routerOS 5.5
any idea?
radionet
Mon Oct 31, 2011 2:01 pm
The problem still exist . The board is rebooting one or two times a day
Rb1200 ros v 5.7 firmware 2.37
Lukas
RADIONET
helectro
Mon Oct 31, 2011 3:28 pm
the 433AHU
now is connected by jack a dc power supply 24V/1A
what happens if connect a POE and also let the current through the jack
be burned?
or work as DC BACKUP?
Sorry my poor English
honzam
Mon Oct 31, 2011 6:51 pm
Lukas
RADIONET
what is in console?
radionet
Mon Oct 31, 2011 6:58 pm
Lukas
RADIONET
what is in console?
radionet
Mon Nov 21, 2011 9:20 am
I upgraded to 5.8 and bios 2.37 but problem still exist .
Now the board is still rebooting but only once a week .
In the log : router was rebooted without proper shotdown (cause1)
Is the still problem with soft ?
Lukas
RADIONET
interprime
Fri Nov 25, 2011 10:11 pm
I'm having the same problem, anyone found a solution?
slech
Mon Nov 28, 2011 12:11 pm
Have the same issue with RB1200, ~ once a week.
I upgraded my RB to latest OS and RouterBoot firmware, but now I can't see firmware version after kernel failure.
[admin@gw] >system routerboard print
routerboard: yes
model: 1200
serial-number: XXXXXX
current-firmware:
upgrade-firmware: 2.37
[admin@gw] >system routerboard settings print
baud-rate: 115200
boot-delay: 5s
enter-setup-on: any-key
boot-device: nand-if-fail-then-ethernet
cpu-frequency: 666MHz<333DDR>
boot-protocol: bootp
enable-jumper-reset: yes
silent-boot: no
[admin@gw] >system package print
Flags: X - disabled
 #   NAME                    VERSION                    SCHEDULED
 0   multicast               5.8
 1   system                  5.8
 2   routeros-powerpc        5.8
 3   security                5.8
 4   ntp                     5.8
 5   ppp                     5.8
 6   dhcp                    5.8
 7   routing                 5.8
 8   routerboard             5.8
 9   user-manager            5.8
10   advanced-tools          5.8
11 X wireless                5.8
12   hotspot                 5.8
13   ups                     5.8
14 X ipv6                    5.8
15   mpls                    5.8
16   gps                     5.8
17   calea                   5.8
sorry for my english
honzam
Tue Nov 29, 2011 12:01 pm
Hello Normis. RB1200 have procesor PPC 460GT-SUB600T it runs on 1000Mhz
But default frekvency for this chip is 667Mhz. It can be a source of problems?
rigan123
Tue Nov 29, 2011 4:18 pm
Could you please check that Watchdog Timer on/off ?
Just go to System>Watchdog and uncheck the timer.
Best Regards,
Rigan.
slech
Thu Dec 01, 2011 6:56 pm
felipesantos
Fri Dec 02, 2011 3:10 am
The problem seems to have been solved by not using the door 9:10. I started using yesterday finally. The equipment was stopped.
felipesantos
Fri Dec 02, 2011 3:13 am
honzam
Fri Dec 02, 2011 10:10 am
I wonder just how it is with the processor? Picture above
normis
Fri Dec 02, 2011 10:14 am
you think we changed the CPU with a software update? :) of course not, so your assumption is not correct. it was purely a software issue with the ethernet driver.
slech
Fri Dec 02, 2011 11:56 am
The cause of reboots is defined correctly ?
RB1200 - MD - eth1, eth2, eth3 - reboot
RB1200 - MD - eth0, eth10 - reboot
RB1200 - UA - eth0, eth10 - good
Ticket#2011112866000373
normis, can you please send me link to pre-release of 5.10, or say the date of the release ?
honzam
Fri Dec 02, 2011 12:20 pm
NO, but PPC 460GT-SUB600T = default frekvency for this procesor chip is 667Mhz and your RB1200 have with this procesor chip default frekvency 1000Mhz.
It means that it is overclocked from production?
slech
Mon Dec 05, 2011 3:47 pm
I updated our RB1200 to 5.10 pre.
After ~ 5 hours it rebooted about 10 times in 20 minutes.
Downgraded to 5.8.
As I mentioned early.
We have RB1200 with eth10 and it works perfect.
And we have RB1200 with eth0, eth1, eth2 - that works like this - restarts every day.
macgaiver
Mon Dec 05, 2011 4:06 pm
Did you sent supout.rif of 5.10 to support@mikrotik.com?
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
felipesantos
Mon Dec 05, 2011 5:14 pm
No send. Equipament in test Verson - 5.9 - 2.38
slech
Mon Dec 05, 2011 5:41 pm
no, because it is a production RB.
kthameen
Mon Dec 05, 2011 6:56 pm
version v5 is a night a pure nightmare better stay on 4.17 if not using nv2, don't hear what they try convince you its a total failure in stablilty
kthameen
Mon Dec 05, 2011 6:59 pm
beware new RBs are not downgraded as for RB433s fw 2.29 is very stable on high loades
normis
Tue Dec 06, 2011 8:49 am
what makes you write such harsh baseless statements?
lan
Thu Dec 08, 2011 4:56 pm
Dear,
i've an 1200, 5.9 frw 2.37, as ospf+mpls router, with all lan used, 2 times of day ospf stuck, if i disable an lan from neighbor router, ospf on 1200 goes up. when i log-in i see BEFORE of FULL->DOWN ethX down. ospf stuck.
any ideas?
Ps: neighbor router is an a rb1100 that work fine.
regards.
Everyday is a school day
Giuseppe M.
Irpinia Net-Com C.T.O.
Wisp and network consulting
http://www.irpinianetcom.it
felipesantos
Sat Dec 10, 2011 4:36 am
Is there any chance of doing a recall on these MikroTik RB1200? In the equipment if there is a solution for it?
normis
Mon Dec 12, 2011 5:23 pm
there is no hardware issue. software bug was fixed already, upgrade RouterOS to new version!
chadd
Thu Dec 15, 2011 5:52 am
Normis,
I am having this same reboot issue with 711 boards, does this problem also include the 711's? If so what software version was supposed to fix it?
normis
Thu Dec 15, 2011 8:28 am
there is no "same" issue with RB711. if they are rebooting, it's because of some other issue. make a new topic or email support.
chadd
Thu Dec 15, 2011 9:06 am
Thanks for reply,
I started a thread here the other day and it disappeared, but there is also one over in the wireless forum that Uldis responded to and I have also sent in several support files to Uldis but haven't heard anything back, I created another ticket tonight for it. Ticket#2011121566000092
I downgraded one of units I am having problems with to 5.6 with 2.36FW. No reboots yet but it hasn't been long enough to tell for sure.
Thanks,
Chadd
slech
Thu Dec 15, 2011 10:50 am
RB1200
ROS 5.8
I disabled IPSec(switched to SSTP) and now have uptime ~ 2d 21h without restarts.
It seems that my troubles were IPSec related(site-to-site IPSec with default encryption).
normis
Thu Dec 15, 2011 10:54 am
slech wrote:
RB1200
ROS 5.8
1. no, this had nothing to do with IPsec
2. THIS IS ALREADY FIXED IN v5.11 !!! Upgrade and there is no more issue on RB1200
slech
Wed Dec 21, 2011 11:39 am
Can confirm that 5.11 resolved my issue.
RB1200
Ports eth1, eth10
ROS 5.11
IPSec site-to-site
Uptime ~ 2 days.
Thank you.
Users browsing this forum: No registered users and 6 guests
