We have 3 internet connection, a 100FDX, 20FDX and a 1000FDX.
At the moment they are all connected to a PowerRouter732 which runs BGP and then that connects to a RB1000 that does local routing (OSPF) and VLANs. The RB1000 connects to a 10/100 switch that needs to be upgrades to a gigabit switch.
Ok, Here's what I want to do.
Drop the 100FDX connection (1000FDX was it's replacement) and then move the 20FDX connection to the RB1000(if it can handle BGP). Then use a RB1200 for the local router for OSPF and VLANs.
I need more ports than the 4 on the RB1000 so the RB1200 seems to be a good fit. The only concern I have is that the RB1200 is not as fast as the RB1000.
I wonder if the PowerRouter732 would be a better choice for a BGP router. ?
Is the RB1000 a better router that the RB1200?
The idea is to have two BGP router connected to each other and a local network router connected to the two BGP routers.
Which routers would up pick for this config/job?
