pakjebakmeel
Jumbo frames 493g
Thu Oct 20, 2011 4:10 pm
I understand that the 493g cannot do jumbo frames. What I can't find is whether this is because of the switch chip or the logic in the rest of the board. Would it be able to use jumbo frames between 2 ports that are in switch mode?
janisk
Re: Jumbo frames 493g
Fri Oct 21, 2011 10:26 am
MAX L2MTU for interface is hardware limitation. You should choose ppc board to get hardware that is capable to transmit and receive larger packets.
http://wiki.mikrotik.com/wiki/Manual:Ma ... uterBoards
elgo
Fri Oct 21, 2011 11:01 am
@pakjebakmeel: interesting question.
@janisk: what piece of harware induce this limitation?
normis
Fri Oct 21, 2011 11:04 am
It's the ethernet PHY, swtichchip affects additional 4 bytes but generally limitation is due to phy
Users browsing this forum: No registered users and 37 guests
