Hi.
I bought RouterBOARD 800, after 1 day and ceased to function. Routerboard was powered through Jack, after 1 day of operation in the source all the burned fuse and has a short circuit at the input jack. Power was a "classic" source transformer with a voltage of 53V max load, under load output voltage is about 48V. I sent this routerboard to dealer, and there I was told that routerboard hight was damaged and that the warranty does not cover it. It was destroyed circuit Q10 no secondary part of the switched power supply. I have a chance this routerboard claim, or already have to change this dealer of RouterBOARD for a new one? Or make switched power supply to powered the routerboard directly .
Thank you.
J.
