it did not have to fix anything yet,Not sure if 5.19 was supposed to fix the power problem, but it hasn't.
I have another RB750UP to modify. I'll go smaller and see where the breaking point is at.CoxWireless you say you could have used a smaller capacitor. What size? That level of electrical is over my head, but I was hoping to solder a cap on my 750UP. Is 24V 1200uf reasonable or what would you recommend?
They added a lot of information here:hi, whith 5.20 on my 750up (poe firmware 2) i'vo got random reboot on ubnt rocket M5. Set "forced on" do nothing.
What to try out??..
log
In the "5.20 Release" thread http://forum.mikrotik.com/viewtopic.php?t=64785 , one has problem with poe on port 4 also.hi, whith 5.20 on my 750up (poe firmware 2) i'vo got random reboot on ubnt rocket M5. Set "forced on" do nothing.
The user in other thread is "sindudas".to Paetur - it is same guy - hagar83 in both topics
to hagar83 - we need more useful information.
Same here. No unexpected behavior to report so far.Bravo for 5.20, it seems to work pretty good.
Hi ...I've got a 35v 220uf capacitor running now (not the 35v 2200uf anymore) and I can power 4 UBNT devices reliably. I'm going to put this in the field tomorrow for real world testing....
set 0 name=ether1-gateway
set 1 name=ether2-master-local poe-priority=10
set 2 master-port=ether2-master-local name=ether3-slave-local poe-out=off poe-priority=10
set 3 master-port=ether2-master-local name=ether4-slave-local poe-priority=10
set 4 master-port=ether2-master-local name=ether5-slave-local poe-priority=10
I have one running with the 35v 220uf capacitor. System-Health reports a constant 21.8VHi ...I've got a 35v 220uf capacitor running now (not the 35v 2200uf anymore) and I can power 4 UBNT devices reliably. I'm going to put this in the field tomorrow for real world testing....
Any updates on that?
Regards;
I have a following configuration and I am little lost here, whether it will work or not.2.5A@24V PSU is over what rb750UP can consume (it is close to that value, so there should not be any issues regarding lack of power).
next problem - 50m - 70m with minimum set resistance for cat5e cable of 0.18Ohm per meter (and this is taken straight out of physics book) so we are talking 9Ohm (50m) and 12.6Ohm(70m) (usually higher quality cables have less resistance) so now calculate the voltage loss over the length of the cable. And then calculate how much power will use connected device when it uses 8W@24V
Does mikrotik have any answer to this?I had found a similar issue as well
@mikrotik You should be able to do this in your lab (this is all your gear):
1. plug in 750UP via 2.5A 24V include supply and computer in ether1
2. load 5.20 and update poe firmware.
3. with default config, only change poe off on ether3:
/interface ethernet4. plug ether1 of RB750 into ether5 of 750UPCode: Select allset 0 name=ether1-gateway set 1 name=ether2-master-local poe-priority=10 set 2 master-port=ether2-master-local name=ether3-slave-local poe-out=off poe-priority=10 set 3 master-port=ether2-master-local name=ether4-slave-local poe-priority=10 set 4 master-port=ether2-master-local name=ether5-slave-local poe-priority=10
5. plug ether1 of RB750G into ether3 of 750UP
6. watch RB750 on ether5 reboot
@CoxWireless, @complete2006, is that what you were seeing? Is that what you meant by "LEDs go crazy"?
EDIT: I found "LEDs go crazy":
3. with default config, ether2 poe off, ether4 poe forced on, ether:
/interface ethernet4. plug ether1 of RB750 into ether3 of 750UPCode: Select allset 0 name=ether1-gateway set 1 name=ether2-master-local poe-priority=10 set 2 master-port=ether2-master-local name=ether3-slave-local poe-out=off poe-priority=10 set 3 master-port=ether2-master-local name=ether4-slave-local poe-priority=10 set 4 master-port=ether2-master-local name=ether5-slave-local poe-priority=10
5. watch LEDs on ether4 of 750UP
6. set ether5 to poe off and the problem goes away
Even if i run poe forced-on the 951 will reboot sometimes. Any tips?I have a 750UP powering 3 951 devices. I must run poe forced-on. Because when I run poe auto-on the devices randomly reboots. any fix to this soon?
admin@PoE Switch] > int eth poe monitor [find]
name: ether2-master-local ether3-slave-local ether4-slave-local>
poe-out-voltage: 23.6V 23.6V
poe-out-current: 16mA 32mA
poe-out-power: 0.3W 0.7W
waiting =)Hold on until I post my update later this week, made a change...
Since Mikrotik isn't updating us on any of this, I reached out to their support email. A couple weeks later, I was told "we are working on completely revised version of firmware."Does mikrotik have any answer to this?
new changed poe-controller firmware will be included into RouterOS 5.22. It will
address "crazy lights" when in auto-on mode, weirdness with ether5 port. However
it will not address issues with forced-on mode.
Ive updated to 5.22
My Firmware is 3.0
My POE Firmware is 2.1
I am powering my 750UP over POE. Cable is long about 50m. Ive checked Ether1 POE over long cable.
I get random reboots (power off/on) on my powered UBNT devices. I have 1 UBNT bullet m2, 1 Airgrid M2 and 1 Airgrid M5.
First time i tried doing it over POE it was version 5.17 i think.. Devices would shut down and power up randomly all the time.
I connected Power adapter directly and everything was working for almost a month.
Now i dont have power in the builing where router is and I was forced to use POE to power on router.
It goes like this.... Some random time in day ... random device/s or all of them go offline. After 5-10 min they get back up.
I have been working with Mikrotik support to no avail on this issue.Modified unit (cox wireless mod) feeding 3 rockets over 200ft. of cat 5 , using 28 v 3.5 a power supply . 750 poe out monitor very very erratic. Rockets in AP mode and are said to be @ 6.5 watts , but I'm seeing monitored spikes up to and in excess of 12w which is crazy. All new units, the only thing I haven't changed is the cat 5 feeding up the tower.
