OrCAD
RB1100AHx2 Problem
Tue Jan 10, 2012 2:38 pm
I received 1100AHx2 and fan system not work in manual and auto.
I check it with Ros5.11
thanks
normis
Re: RB1100AHx2 Problem
Tue Jan 10, 2012 2:41 pm
fan doesn't work at all, or what is the problem exactly?
OrCAD
Tue Jan 10, 2012 3:17 pm
fan don't start, in manual mode (main or auxiliary).... in auto and CPU Temp 41°C don't start... what is the minum temp to start in auto mode?
thanks
normis
Wed Jan 11, 2012 9:06 am
Is the fan connected to the board? check the wires, are they connected tight? unplug and re-plug the fan
janisk
Wed Jan 11, 2012 11:50 am
is the CPU radiator hot? if not fan will not work Fan speed for RB1100AHx2 is automatically regulated and if CPU is cold fans will not turn on. Also, if temperature increases so will RPM of the fan.
OrCAD
Fri Jan 13, 2012 1:00 pm
Ok, thanks..
I see the fan up when cpu 100% or heatsink is over 40°C
good job.
thanks
Users browsing this forum: No registered users and 39 guests
