Like^2.
Spend you time an energy to make an RB1200 without TX-Ports and only SFP slots. There is no product with a good price in the market.
Bad luck for 100FX (or any other 100Base) at the moment...Like a previous post, I would like to see some other supported SFP's such as 100FX and 1000SX
FYI the RB2011 DOES NOT support reading of A0h/A2h stats as per SFF-8472.
According to Mikrotik this feature may be added to future products.
does not support Ad-Net SFP155-WDM1310/10
http://www.ad-net.com.tw/index.php?id=294
Is it possible to add support for this SFP?
It is obvious, but what about other named items?it does not support poe-out. that will be fixed
http://www.qca.qualcomm.com/media/produ ... _file1.pdfThe remaining 2 ports feature a standard GMII/RGMII/MII/Serdes interface to
allow connection to a host CPU in PON/xDSL/Cable/Wifi/Fiber routers.
Of course. That`s the human life. If you stop to crying for something, your life will stop, that`s end of your life. We, customers always want more and more. It drives Mikrotik to be more strong and valuable vendor. Btw, our company deployed very large network using some kind of 155mbps SFP. So we can not just change all our node equipment once. So we still need to continue using 155mbps SFP until node equipment upgraded to 1.25Gbps.Even the same game,
all are crying and begging for anything new, then MikroTik is doing do, and after the launch the whole
crowed turns around and is crying for another feature, option and\or functions!
The same procedure as every year.
- At first crying to get SFP ports and support
- Then crying why no 100 MBit\s
- After this crying for 10 GBit\s support but no ones want to pay for the switch fabric inside that must be soldered in
- If this was done by MikroTik, all are crying for 10 GBit\s Ethernet Ports copper based and GEO stacking support.
Like the lemmings, one is turning left and the whole crowed is following into the deep abyss.
Yes, I`m agree with you. Therefor I`m trying to vote for 100mb SFP. But of course final decision will be done by MT guys. They do not make features, what I posted once. I`m trying to increase vote on this feature request. An other hand, it`s very good thing for MT that people always post feature requests. People still want to use MT for wide area in their network. They want to done their demands by MT products. Your case, your life is different from me. You don`t need some features, but maybe I don`t need features, what you want. So please don`t disclaim other`s wishes or don`t try to place your wish before other`s . But I`m agree with you that future OS, future routers will be supported more features and it`s not easy to develop features, such as mine.At last I think really it is not so easy to fit all the needs and serve all the wishes from all customers, but I think also they are on the road and do a fine job, to come nearly to this state.
Hi Dobby, I don`t think your posts are rude. . When I was posting previous posts, I had nice face with smile. So don`t worry, it`s ok. Finally we all love to be customer of Mikrotik.So please accept that I don´t want to blame, kidding, to bother or what ever else you, this was more a try out to
explaining why their is no 100 MBit/s SFP support and not that this is not needed!
I am more afraid of having 10 GBit/s support, because this equipment should not so cheap to build and is perhaps more wished and then not bought, like the 100 MBit/s. Not that you thing I am not able to use it
For our clients:Which SFP module features would be most important for you?
This SFP works with rb2011LS ?For our clients:Which SFP module features would be most important for you?
Digitus DN-81103 http://datasheet.digitus.info/en/4016032305705.html
155 Mbps
TX 1310 nm
RX 1550 nm
20 km
3,3V
Transmission Power: Minimum -15 dBm, Maximum -8 dBm
Sensitivity Receiving Power: Minimum -32 dBm
And for us (in order to be able to test client setups and hardware):
Digitus DN-81104 http://datasheet.digitus.info/en/4016032305712.html
155 Mbps
TX 1550 nm
RX 1310 nm
20 km
3,3V
That's really interesting. Can the RB2011UiAS handle the 4.25Gbps transfer rate or is it still restricted to 1Gbps ?Hi,
I'd like to report that I successfully tested Finisar FTLF8524P2BNV with Gigabit Ethernet on RB2011UiAS-2HnD-IN.
http://www.finisar.com/sites/default/fi ... 20RevJ.pdf
It can be added to http://wiki.mikrotik.com/wiki/Supported_Hardware
From what I understand, it's 1.25Gbps max in Ethernet mode, 4.25Gbps is Fiber Channel.That's really interesting. Can the RB2011UiAS handle the 4.25Gbps transfer rate or is it still restricted to 1Gbps ?Hi,
Please tell me about which sfp module did you use? I need it deperately.I am testing a pair of bidi SFPs. I get a link and also get traffic across the link (how may or reliable it is, I do not know), but these RB2011LS-INs are at loss as status of a sfp1 interface does always state:
Auto Negotiation: done
Rate: Unknown
Full duplex is unchecked
Some other items:
PoE Out Current: 0mA
Does sfp1 has a PoE support?
Also, [Blink] button in Winbox does not blink [USR] led of the device.
Running ROS v5.19.
