I have more than 50 sets of RB450G. All of them are working stable over 1 years. Recently, I use netinstall to upgraded RouterOS from 4.17 to 5.14. Most of them are working properly as usual, but one is crashed. I always got an error messge "disk is too small" in the installation stage. After many times fail, I gave up, through netinstall, I can reinstall this RB450G downgrade to 4.17. It works properly with 4.17 once again. I check the free space = 477.8MB, bad block=8 and license upgradable to v6.x. Can someone tell me what's wrong with this RB450G?
ps. both firmware 2.29 and 2.39 got the same error
janisk wrote:
what you see in
Code:
/system resources
and i did not understand, you re-installed it using netinstall tool?
can you install 5.14 on the board using netinstall?
Yes, after upgrade 5.14 fail, I use netinstall to install 4.17, it is OK. I did use netinstall to install 5.14, but it's always show ERROR: installation of system-5.14 failed: disk is too small.
File comment: the result of "system resource print" snap2.jpg [ 138.83 KiB | Viewed 964 times ]
DynStatic wrote:
/system check-disk
Do a supout.rif and send it to Mikrotik.
I tried to send supout.rif to Mikrotik support, but always got the message "Invalid supout.rif file." But the same supout.rif file can be uploaded by Mikrotik supout.rif reader page and looked normally.
File comment: Invalid message after sending snap4.jpg [ 313.41 KiB | Viewed 865 times ]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
