Which card rate to specify?Fix:
Change this parameter in wireless:
Advanced Distance=Dynamic
Tx Power--> TX power Mod: Card Rates
30mbit is a little bit few from a device, which should generate lot more.I tested it some days ago with ROS 5.21, and got a little over 30mbit upload and download speed, with standard wireless settings.
Works ok for me
No, I don't think these devices are capable of doing 30mbytes. 30mbits, on the other hand, sounds normal for an Internet connection.30mbit is a little bit few from a device, which should generate lot more.
Or you meant 30mbyte
I just made the supout file, I opened it with notepad++ it's coded, I need to know what info is there ? if my passwords are there too, then I would not want it to be seen by anybody...what wireless data-rates it is using when you are doing the test? Make support output file and send that to support@mikrotik.com
you want your problem fixed or not? send the file and don't worryI just made the supout file, I opened it with notepad++ it's coded, I need to know what info is there ? if my passwords are there too, then I would not want it to be seen by anybody...what wireless data-rates it is using when you are doing the test? Make support output file and send that to support@mikrotik.com
anybody knows if the passwords are there too ?
export compact
# dec/03/2012 22:53:00 by RouterOS 5.22
# software id = xxxx-xxxx
add l2mtu=1598 name=bridge1
add authentication-types=wpa-psk,wpa2-psk eap-methods=passthrough \
management-protection=allowed mode=dynamic-keys name=yamaha \
supplicant-identity="" wpa-pre-shared-key=xxxxxxxxxxxxxx \
wpa2-pre-shared-key=xxxxxxxxxxxxxx
/interface wireless
set 0 band=2ghz-b/g/n disabled=no frequency=2437 l2mtu=2290 mode=ap-bridge \
security-profile=yamaha ssid=yamaha
add bridge=bridge1 interface=wlan1
/ip dhcp-client
add default-route-distance=0 disabled=no host-name=wifi interface=ether1 \
use-peer-dns=no
/ip firewall service-port
set ftp disabled=yes
set irc disabled=yes
/ip service
set "" disabled=no port=22
/system clock
set time-zone-name=Europe/Oslo
/system identity
set name=WiFi
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes mode=unicast
/tool bandwidth-server
set enabled=no
[root@WiFi] >
0 R name="wlan1" mtu=1500 mac-address=D4:CA:6D:55:C6:DD arp=enabled
disable-running-check=no interface-type=Atheros AR92xx
radio-name="RB751U_radio" mode=ap-bridge ssid="XXXXXXX" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2442 band=2ghz-b/g/n channel-width=20/40mhz-ht-below
scan-list=default wireless-protocol=802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=dynamic tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=Xxxxxx disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,
mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
multicast-helper=default
0 R name="wlan1" mtu=1500 mac-address=D4:CA:6D:20:D1:9D arp=enabled
radio-name="D4CA6D20D19D" mode=ap-bridge ssid="wifree.si" area=""
frequency=2412 band=2ghz-b/g/n channel-width=20/40mhz-ht-above
scan-list=default wireless-protocol=any rate-set=default
54Mbps
distance=indoors tx-power-mode=default noise-floor-threshold=default
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=any
ht-txchains=1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
nv2-preshared-key="" hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
Just to be clear, such device does not exist. Myso was asking aboud RB951G-2HnD. You are probably using RB951-2n.RB951G-2n has really bad performance too... About 10/2 mbits. So i guess it's not much better.
This is not RB951G-2n, it is RB951-2nUfcorse it does http://routerboard.com/RB951-2n
try out to disable them sending TOS nad test it again pleasemostly Apple devices and
Would be fine.I'll keep you up-to-date with this.
c:\soft>iperf -c 10.69.4.53 -P 20 -w 512k -t 60
Client connecting to 10.69.4.53, TCP port 5001
TCP window size: 512 KByte
[280] local 10.69.4.54 port 50095 connected with 10.69.4.53 port 5001
[264] local 10.69.4.54 port 50093 connected with 10.69.4.53 port 5001
[248] local 10.69.4.54 port 50091 connected with 10.69.4.53 port 5001
[232] local 10.69.4.54 port 50089 connected with 10.69.4.53 port 5001
[216] local 10.69.4.54 port 50087 connected with 10.69.4.53 port 5001
[200] local 10.69.4.54 port 50085 connected with 10.69.4.53 port 5001
[184] local 10.69.4.54 port 50083 connected with 10.69.4.53 port 5001
[168] local 10.69.4.54 port 50081 connected with 10.69.4.53 port 5001
[152] local 10.69.4.54 port 50079 connected with 10.69.4.53 port 5001
[136] local 10.69.4.54 port 50077 connected with 10.69.4.53 port 5001
[272] local 10.69.4.54 port 50094 connected with 10.69.4.53 port 5001
[256] local 10.69.4.54 port 50092 connected with 10.69.4.53 port 5001
[224] local 10.69.4.54 port 50088 connected with 10.69.4.53 port 5001
[208] local 10.69.4.54 port 50086 connected with 10.69.4.53 port 5001
[192] local 10.69.4.54 port 50084 connected with 10.69.4.53 port 5001
[176] local 10.69.4.54 port 50082 connected with 10.69.4.53 port 5001
[160] local 10.69.4.54 port 50080 connected with 10.69.4.53 port 5001
[144] local 10.69.4.54 port 50078 connected with 10.69.4.53 port 5001
[128] local 10.69.4.54 port 50076 connected with 10.69.4.53 port 5001
[240] local 10.69.4.54 port 50090 connected with 10.69.4.53 port 5001
[ ID] Interval Transfer Bandwidth
[184] 0.0-60.4 sec 57.0 MBytes 7.92 Mbits/sec
[216] 0.0-60.5 sec 54.3 MBytes 7.53 Mbits/sec
[168] 0.0-60.5 sec 52.3 MBytes 7.25 Mbits/sec
[272] 0.0-60.6 sec 50.9 MBytes 7.05 Mbits/sec
[256] 0.0-60.7 sec 38.3 MBytes 5.29 Mbits/sec
[240] 0.0-60.7 sec 40.3 MBytes 5.58 Mbits/sec
[144] 0.0-60.7 sec 30.2 MBytes 4.17 Mbits/sec
[224] 0.0-60.8 sec 39.7 MBytes 5.47 Mbits/sec
[128] 0.0-60.8 sec 50.3 MBytes 6.94 Mbits/sec
[160] 0.0-60.8 sec 39.9 MBytes 5.51 Mbits/sec
[200] 0.0-60.8 sec 36.6 MBytes 5.04 Mbits/sec
[192] 0.0-61.0 sec 11.8 MBytes 1.62 Mbits/sec
[248] 0.0-61.0 sec 11.9 MBytes 1.64 Mbits/sec
[232] 0.0-61.0 sec 11.9 MBytes 1.64 Mbits/sec
[136] 0.0-61.0 sec 11.8 MBytes 1.62 Mbits/sec
[280] 0.0-61.0 sec 12.0 MBytes 1.65 Mbits/sec
[264] 0.0-61.0 sec 12.0 MBytes 1.65 Mbits/sec
[152] 0.0-61.0 sec 11.8 MBytes 1.62 Mbits/sec
[176] 0.0-61.0 sec 11.8 MBytes 1.62 Mbits/sec
[208] 0.0-61.0 sec 11.8 MBytes 1.62 Mbits/sec
[SUM] 0.0-61.0 sec 597 MBytes 82.0 Mbits/sec
6 WiFi 00:16:EA:xx:xx:xx no -62dBm@1Mbps 135.... 5m37s
int wirele print
0 R name="WiFi" mtu=1500 mac-address=00:0C:42:xx:xx:xx arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="xxxx" frequency=2437 band=2ghz-b/g/n
channel-width=20/40mhz-ht-above scan-list=default wireless-protocol=unspecified wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=xxxx compression=no
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=10 area="" arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=\
20/40mhz-ht-above compression=no country="czech republic" default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=2437 frequency-mode=regulatory-domain frequency-offset=0 hide-ssid=no \
ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any ht-rxchains=0,1 \
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 \
ht-txchains=0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=00:0C:42:B7:9B:23 max-station-count=2007 \
mode=ap-bridge mtu=1500 multicast-helper=default name=WiFi noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
post-2.9.25 radio-name=000C42xxxxxx rate-selection=advanced rate-set=default scan-list=default security-profile=xxxx ssid=xxxx station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=unspecified wmm-support=\
disabled
/interface wireless manual-tx-power-table
set WiFi manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17\
,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
I had a RB751G 2HnD with poor Wireless, I downgraded to 5.16 and it is greatI am experiencing a lot of problems with wireless devices connected to the RB751-2HnD.
I bought 3 units, in 2 different periods of time (2 when they became available several months ago, and one which arrived today). Local distributor said the last one is a new revision.
They are all configured as an access-point (802.11 b/g/n), and I get a lot of disconnections and very poor performances (high latency, variable between 40 and 3000ms, 100kbit/s throughput). If I manually set noise-floor to -90dB it becomes usable, but still I have reliability problems.
There are no interferences on the channel and devices work very well when connected to other access-points.
I already tried different ROS versions (5.6, 5.7, 5.9 and 5.14). All show the same behaviour on all units.
Does it happen only to me?
It sure did help! Sorry for necrobumping this thread, but I just wanted to say that #2 and #4 in scampbell's list were the key to *finally* solving major issues with "disconnected, extensive data loss" errors on my network. (In my case, the devices were laptops with Intel WiFI chipsets, not mobile devices.) I've been fighting with this for weeks, and I've tried everything. Especially when doing large file transfers over the LAN with several connections to the same device, it would consistently disconnect after a few seconds to a few minutes, with "extensive data loss" in the logs. According to NetworkManager on the clients, the disconnects were for "reason -4". So I finally ran across this thread, made changes #2 and #4, and after extensive network stress testing I can say I haven't had a single disconnection. Then I reset the WiFI distance to "dynamic" and power levels to "default", and *boom*, a disconnect with "extensive data loss" within less than a minute. Re-applied #2 and #4, and it runs fast and stable. Another added benefit of this change is that my network throughput is almost twice as fast. So thanks again to scampbell!1. Use a current RoS
2. Set tx power to 17dBm
3. Use Channel width=20MHz - 20/40MHz is not universally accepted by all devices and uses a lot of spectrum
4. Set distance=indoors
5. Disable TKIP in your security profiles - it limits speed to 54Mbps
6. Set ht-tx-chain=0,1 and ht-rx-chain=0,1 where supported
7. Set Guard Interval=long - allows for slower devices
I hope this helps.
WelcomeIt sure did help! Sorry for necrobumping this thread, but I just wanted to say that #2 and #4 in scampbell's list were the key to *finally* solving major issues with "disconnected, extensive data loss" errors on my network. (In my case, the devices were laptops with Intel WiFI chipsets, not mobile devices.) I've been fighting with this for weeks, and I've tried everything. Especially when doing large file transfers over the LAN with several connections to the same device, it would consistently disconnect after a few seconds to a few minutes, with "extensive data loss" in the logs. According to NetworkManager on the clients, the disconnects were for "reason -4". So I finally ran across this thread, made changes #2 and #4, and after extensive network stress testing I can say I haven't had a single disconnection. Then I reset the WiFI distance to "dynamic" and power levels to "default", and *boom*, a disconnect with "extensive data loss" within less than a minute. Re-applied #2 and #4, and it runs fast and stable. Another added benefit of this change is that my network throughput is almost twice as fast. So thanks again to scampbell!1. Use a current RoS
I hope this helps.
There are similar suggestions here too: https://gryzli.info/2015/06/20/mikrotik ... rformance/
