RB1100AH
have been tested and "stocked" for 3 months, after that the problem
sorry by my english
Code: Select all
RouterBOOT booter 2.37
RouterBoard 1100AH
CPU frequency: 1066 MHz
Memory size: 2048 MB
Press any key within 2 seconds to enter setup..
trying bootp protocol......... failed
kernel loading failed
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
modprobe: could not parse modules.dep
/etc/rc.d/run.d/S02logring: 10: cannot create /dev/log241: No such device or add
ress
/etc/rc.d/run.d/S02panic: 2: cannot create /dev/log241: No such device or addres
s
/etc/rc.d/run.d/S05syslog: 4: cannot create /dev/log240: No such device or addre
ss
/etc/rc.d/run.d/S07rb: 4: cannot create /dev/log241: No such device or address
/etc/rc.d/run.d/S07watchdog: 3: cannot create /dev/log241: No such device or add
ress
/etc/rc.d/run.d/S08softdog: 3: cannot create /dev/log241: No such device or addr
ess
Starting services...
/etc/rc.d/run.d/S10nova: 6: cannot create /dev/log1: No such device or address
Fatal error 0x853
Please contact support@mikrotik.com
socket failed (errno=97)
Shutting down...
Stopping services...
/etc/rc.d/run.d/C95panic: 2: cannot create /dev/log241: No such device or addres
s
Power down.
System Halted, OK to turn off power
