stmx38
Long time Member
Long time Member
RB1100AH ports name via Terminal, SNMP and Physical
Fri Jun 29, 2012 10:25 am
I in process to create Zabbix template for RB110AH, but i bit confused with ports name:
ROS 5.18
In this case to monitor Eth1 physical port I should poll ether1-lan (1.3.6.1.2.1.2.2.1.2.3)
Why Eth1 is not 1.3.6.1.2.1.2.2.1.2.1 ?
Can someone provide me its print ?
/interface ethernet print
Thanks.
stmx38
Long time Member
Long time Member
Re: RB1100AH ports name via Terminal, SNMP and Physical
Fri Jun 29, 2012 10:46 am
RB1200 - ROS 5.11
 0    ether10
 1    ether9
 2    ether7
 3    ether8
 4    ether6
 5 R  ether5                 Eth5
 6    ether4
 7    ether3-wan-backup
 8    ether2-wan-primary
 9    ether1-lan
# after reset
 0    ether10      Eth10    ifDescr.1
 1    ether9       Eth9     ifDescr.2
 2    ether7       Eth7     ifDescr.3
 3    ether8       Eth8     ifDescr.4
 4    ether6       Eth6     ifDescr.5
 5 R  ether5       Eth5     ifDescr.6
 6    ether4       Eth4     ifDescr.7
 7    ether3       Eth3     ifDescr.8
 8    ether2       Eth2     ifDescr.9
 9    ether1       Eth1     ifDescr.10
stmx38
Long time Member
Long time Member
Fri Jun 29, 2012 10:52 am
RB433UAH
0 R ether1-wan-primary  Eth1
1 R ether2-lan          Eth2
2 X ether3-empty        Eth3
Here all is ok!
janisk
Fri Jun 29, 2012 1:41 pm
RB800
iso.3.6.1.2.1.2.2.1.2.1 = STRING: "ether3"
iso.3.6.1.2.1.2.2.1.2.2 = STRING: "ether1"
iso.3.6.1.2.1.2.2.1.2.3 = STRING: "ether2"
RB600 and RB600A will have the same order as RB800
Users browsing this forum: li77616211 and 89 guests
