you can attach this to powered USB hub and still use it as USB port.Going back to the question kurtkraut asked - is there any reason I can't (by custom cable) inject 5v power via USB /and/ use the USB port at the same time?
Looking at the spec sheet here and here the answer should be quite obvious.What about WiFi range and link quality compared with rb951g-2hnd or rb751u-2hnd?
What is better for 60m^2 flat (only indoor usage):
Any ethernet router + mAP-2n
or
rb951g-2hnd?
You want to set up mAP as wireless client of an existing access point, and then you want to connect the credit card terminal to mAP via ethernet cable?The issue im trying to figure out is the user will not have access to the config page and needs a feedback that its connected to the wifi! I was thinking a beep script would have worked but looking at the posted hardware pictures i don't see any speaker built in! any advice on how to best do this? i see there is a AP lite and a actual wifi lite not sure if on would stay off when its not connected to a ap and turn on if it dose in client mode?? that would work.
This device support power reset ?
I connect usb yota ltu150
[admin@mk01] > system routerboard pr
routerboard: yes
model: RouterBOARD mAP 2n
serial-number: 51FD049F496A
current-firmware: 3.17
upgrade-firmware: 3.17
[admin@mk01] > system routerboard usb pr
usb-mode: automatic
bootstrap: host-mode
[admin@mk01] > system routerboard usb power-reset
ERROR: USB power reset not implemented on this hardware
This is an absolute dealbreaker for me... had big plans for this little router.no. it does not heat up. You can press your hand against the router when it is working configured and loaded for max consumption and that is an unlikely scenario for the device.
And it arrives! Interesting that mAP2n dissapear from official routerboard.com site.Looks like there's an upgraded version incoming — mAP-2nD. Probably it will.
Guys, sorry for late reply, I had a very rough summer lately.Put your wlan interface in ap-bridge mode
# sep/14/2016 16:45:20 by RouterOS 6.36.3
# software id = GU9G-Z1DB
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=romania disabled=no mode=ap-bridge wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=password\
wpa2-pre-shared-key=password
/ip hotspot profile
add bridge=bridge1 interface=wlan1
add address=192.168.0.253/24 interface=ether2 network=192.168.0.0
set servers=192.168.0.250,192.168.0.246
/ip dns static
add address=192.168.0.253 name=router
add distance=1 gateway=192.168.0.254
/system identity
set name=mAP-2nD
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
[admin@mAP-2nD] >
On devices with multiple ports, they tend to only print the first and last mac addresses of the range.There is a missing gap, I think they don't print out all Mac
Hi Normis.Wireless will become "R" only when you connect to it. If you scan for networks, do you see it's SSID name?
# sep/15/2016 11:37:26 by RouterOS 6.36.3
add admin-mac=E4:8D:8C:09:A4:42 auto-mac=no name=myBridge
/ip neighbor discovery
set ether1 discover=no
set ether2 discover=no
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=myWPA2 supplicant-identity="" wpa-pre-shared-key=password wpa2-pre-shared-key=password
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=romania disabled=no distance=indoors frequency=2452 mode=ap-bridge security-profile=myWPA2 ssid=mAP wireless-protocol=802.11
set wlan1 discover=no
/ip hotspot profile
add bridge=myBridge interface=ether2
add bridge=myBridge interface=wlan1
add bridge=myBridge interface=ether1
add address=192.168.10.251/24 interface=ether2 network=192.168.10.0
/ip dhcp-relay
add dhcp-server=192.168.10.254 disabled=no interface=myBridge name=relay1
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.251 name=router
add distance=1 gateway=192.168.10.254
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=mAP-2nD-frt01
/tool mac-server
add interface=myBridge
Routerboard.com says mAP has voltage monitor (click box under "Features"). mAP product page says mAP has voltage monitor. Winbox says mAP has no voltage monitor. Wish I knew whether this was a Winbox bug or a marketing bug.no, it will not have voltage monitor.
So, in summary, can we pass 802.3af PoE in to the mAP2nD and get 802.3af PoE out of it?802.3af PoE is working OK this time.
sometimes it would be useful to check at what date, month or year the comment is made. And maybe notice that most probably that is done for the previous revision in 2014.Routerboard.com says mAP has voltage monitor (click box under "Features"). mAP product page says mAP has voltage monitor. Winbox says mAP has no voltage monitor. Wish I knew whether this was a Winbox bug or a marketing bug.no, it will not have voltage monitor.
Not sure about 802.3af in ether2, but an active PoE device turns on instantly and works well...So, in summary, can we pass 802.3af PoE in to the mAP2nD and get 802.3af PoE out of it?
hAP ac lite with gigabit ports and in a smaller package for the price of hAP ac liteWhat about a mAP AC lite with AF/AT power and 2-3 10/100/1000 ports
This would rock in a dorm room. If the price point could be around the hAP AC Lite
I'd like it to be type-cWould be great to add USB-NIC mode - mAP gains 3rd Ethernet interface via USB.
Yes, type-c would be optimal, but could port be more "compatible" with possibility of use micro-USB type-B compatible (depends from controller).hAP ac lite with gigabit ports and in a smaller package for the price of hAP ac liteWhat about a mAP AC lite with AF/AT power and 2-3 10/100/1000 ports
sure, I'd buy that!
+1 - Everyone has a handful of old micro-b chargers at home they're not using that can be given a second life.Yes, type-c would be optimal, but could port be more "compatible" with possibility of use micro-USB type-B compatible (depends from controller).
According to the manual for the Yealink W52P it is an 802.3af device, and I doubt that Cisco SB PoE switch is anything other than 802.3af, so I think your answer to my question is "yes"!Not sure about 802.3af in ether2, but an active PoE device turns on instantly and works well...So, in summary, can we pass 802.3af PoE in to the mAP2nD and get 802.3af PoE out of it?
Unfortunately not (I've just tried this). I knew it would be a long shot (and would probably exceed the current that USB can put out) but just wanted to try it anyway.When connected to USB is it able to power a sxt with poe?
Thanks for clarifying. I was just about to buy mAP. But, wanted to make sure it can power SXT with PoE when powered via USB. Yes, a firmware update would be nice.Unfortunately not (I've just tried this). I knew it would be a long shot (and would probably exceed the current that USB can put out) but just wanted to try it anyway.When connected to USB is it able to power a sxt with poe?
However, the "PoE out" LED still comes on when powering from USB. MikroTik, may I suggest a firmware update to turn this LED off when powered from USB, to avoid confusion?
