harrysuccess
Re: New hardware - mAP
Tue Jun 24, 2014 2:15 am
still waiting :)
HaPe
Mon Jun 30, 2014 5:33 pm
First MikroTik with support for 802.3af?
cbrown
Trainer
Trainer
Mon Jun 30, 2014 8:54 pm
Nope, the RB800 does.
http://routerboard.com/RB800
normis
Tue Jul 01, 2014 2:14 pm
RB230 was actually the first, but yes, RB800 also supports it. and the new mAP will.
janisk
Tue Jul 01, 2014 2:56 pm
All interfaces are functional. And as with routers that have a lot of addresses to list there, so first and last address is given.
Do not forget RB600 ;)
nz_monkey
Wed Jul 02, 2014 12:15 am
I still have an RB600 going strong, great router :)
payday
Wed Jul 02, 2014 4:55 pm
When? :)
Will it be in next newsletter?
payday
Mon Jul 07, 2014 12:29 pm
Product Catalog says: "The mAP is a tiny size wireless Access Point with full RouterOS capabilities."
So I wonder: Will CAPsMAN work on mAP?
jarda
Mon Jul 07, 2014 1:03 pm
Why the map is not still available on the market?
janisk
Mon Jul 07, 2014 1:23 pm
It will have level 4 license. So yes, you will be able to run CAPsMAN on it.
ronniee
Mon Jul 07, 2014 4:08 pm
will be available soon? maybe this month?
or only after summer break?
mcdebugger
Sun Jul 20, 2014 4:27 pm
I see AP/CAP led on the pictures. Does it mean it was designed from start to work as a CAP with CAPsMAN and can indicate that it's controlled by the manager or works as a standalone AP?
Is 0.8A real power consumption of the mAP? It means it can't be powered by other mAP via PoE? In my mind I have some strange scheme of these devices plugged in chain and attached to CAPsMAN :shock:
ohara
Sun Jul 20, 2014 4:44 pm
mAP should be 802.11ac, otherwise waiting doesn't pay off, no?
payday
Mon Jul 21, 2014 12:36 am
802.11ac is 5GHz only. At the moment most devices are using 2GHz N. So, 802.11ac in Access Point makes sense only if it is dual-band with two radios: 5GHz AC + 2GHz N.
payday
Mon Jul 21, 2014 12:58 am
This seams to be true.
Excerpts from mAP user manual:
"The PoE on Ether2 outputs approximately 2V below input voltage, and supports up to 0.5A (So provided 24V PSU will provide 22V/0.5A output to the Ether2 PoE port)."
"Under maximum load, the power consumption of this device is 4W (when not using PoE output)."
This means that mAP will need less then 0.16A (using provided 24V PSU or any other 24V POE). Theoretically another mAP in chain will require less then 0.18A due to lower voltage (22V).
janisk
Mon Jul 21, 2014 2:11 pm
also, that is MAX consumption, not the usual one. It will be hard for any of you to reach that on that device. So in usual circumstances power usage will be less.
Petzl
Mon Jul 21, 2014 2:48 pm
I'm intrested to build them inside alarm systems to use them as a VPN gateway, no more messing with port forwarding and dyndns ...
so the question is : will it be cheaper than a 951 ?
wcsnet
Mon Jul 21, 2014 6:33 pm
The question is why are these not available yet :?
juliobrito
Mon Jul 28, 2014 3:54 am
Still Waiting :( :? :(
honzam
Mon Jul 28, 2014 11:13 am
Presentation from February 2014 and still nothing
New brochure with mAP and others: http://download2.mikrotik.com/2014-Q1.pdf
You say Q1. Now is Q2 and mAP is where? We need it
mapunda
Tue Jul 29, 2014 10:19 am
Will this mAP device have voltage monitor? I am thinking to use the device to monitor -48v telecom site.
nkourtzis
Tue Jul 29, 2014 12:26 pm
The mAP will be, among other things, an excellent portable diagnostic device for all us network professionals to carry along at all times (on field trips etc). Plus it could be easily configured to automatically create an EoIP tunnel to our main router, over any network. I can think of so many uses for it... Let's hope it will be available before the end of this year. Ideally with a dual band radio.
normis
Tue Jul 29, 2014 12:36 pm
mAP has not disappeared anywhere. We simply are doing very detailed testing, and had to improve some things before we can manufacture it. This caused the delay. The good news is that it's nearly ready to go on sale!
erikje
Wed Jul 30, 2014 2:28 pm
nice! I can use a few of those to get decent wifi coverage in my house :)
nkourtzis
Wed Jul 30, 2014 3:25 pm
Good news, Normis. Indeed, it is always better, long term, to market a thoroughly tested product than rush things out the door and then invent "revisions" (keep this in mind also regarding RouterOS releases).
Is this also the case with RB850Gx2? How close is this one to mass availability?
normis
Wed Jul 30, 2014 3:26 pm
Good news, Normis. Indeed, it is always better, long term, to market a thoroughly tested product than rush things out the door and then invent "revisions".
both very close
nkourtzis
Wed Jul 30, 2014 3:29 pm
Is there any way the more adventurous side of us can get some satisfaction by gaining early access to such "beta" hardware? Just curious...
normis
Wed Jul 30, 2014 3:39 pm
There is usually some actual reason it's not for sale yet, you probably don't want such hardware :) But in any case, no, we don't offer any test hardware before the general release.
mac112
Fri Aug 08, 2014 11:08 pm
jarda
Fri Aug 08, 2014 11:22 pm
USD 45? I expected much lower price...
nz_monkey
Fri Aug 08, 2014 11:36 pm
$45 is a bargain!
It has 802.3af remember
mac112
Sat Aug 09, 2014 8:28 pm
Unfortunately, it's the similar as RB951-2n, so the price will be similar.
I expect that it will slow. Mikrotik uses in mAP-2n flash memory SPI bus. Memory is Winbond 25Q128 128MBit (16mbyte) with 100.000 erase/program cycles. In the RB951-2n are used parallel flash K9F1208. RB951-2n is still better 5x ETH,option of a USB (self made).
mac112
Wed Aug 13, 2014 8:19 pm
dealer sales is 34$
Petzl
Wed Aug 13, 2014 10:39 pm
http://www.interprojekt.com.pl/mikrotik ... -1644.html
27.64 euro, introduction price, lets hope it will get cheaper in time ....
normis
Thu Aug 14, 2014 8:00 am
It is 10$ cheaper than when we first announced it :)
Valerio5000
Fri Aug 15, 2014 3:16 am
Wireless is 500 mW ?
cbrown
Trainer
Trainer
Fri Aug 15, 2014 4:25 am
mac112
Fri Aug 15, 2014 12:36 pm
No 500 mW but 50.0 mW => 17 dBm
otgooneo
Trainer
Trainer
Mon Aug 18, 2014 6:49 am
Does anyone know what is the wireless power of mAP (AR9331-AL1A)? 1000mW?
DBob
Mon Aug 18, 2014 9:20 am
Maybe you should check the posts above yours...
(write only user?)
mac112
Tue Aug 19, 2014 8:04 pm
Chip Atheros AR9331-AL1A used in the TL-WR703N and TL-MR3020 mini pocket routers.
The manufacturer TPLINK present WiFi power < 20dBm ERPI with simple two antennas.
There is a calculator http://rfcalculator.mobi/convert-eirp-dbm.html
20dBm ERPI for power chip out 17,86dBm
17dBm is 50mW
is it wrong ?
janisk
Wed Aug 20, 2014 11:12 am
no, it is not wrong, mAP has a 50mW radio. Phone/laptop AP.
dorijan
Fri Aug 22, 2014 5:06 am
Will usb support ethernet mode for laptops without ethernet ports?
Aveyer
Tue Sep 02, 2014 6:13 am
Just got the mAP in my hands, it's an awesome product.
Good job Mikrotik.
janisk
Tue Sep 02, 2014 10:23 am
no, it will not work as an ethernet interface. You can power it via USB and connect to it wirelessly.
ste
Re: AW: New hardware - mAP
Tue Sep 02, 2014 3:25 pm
When connected to USB is it able to power a sxt with poe?
jarda
Tue Sep 02, 2014 4:14 pm
I would not expect that. It passes poe thru but does not have step-up voltage convertor.
rjickity
Wed Sep 03, 2014 5:14 am
i have 2x mAP's here but the 802.3af must be magic as it hasn't worked on any of my cisco 3560's... powers via passive no problems but definitely no dice from 802.3af switch
edit: looks like its not just me http://forum.mikrotik.com/viewtopic.php ... de#p445434 well guess that these are no good for what we had intended them for now
normis
Thu Sep 04, 2014 6:31 pm
did you try crossover cables?
littlebill
Thu Sep 04, 2014 11:10 pm
im excited, mine is coming tomorrow
tehdan
Fri Sep 05, 2014 3:08 pm
Going back to the question kurtkraut asked - is there any reason I can't (by custom cable) inject 5v power via USB /and/ use the USB port at the same time?
murphy
Fri Sep 05, 2014 4:08 pm
This device support power reset ?
I connect usb yota ltu150
[admin@mk01] > system routerboard pr
routerboard: yes
model: RouterBOARD mAP 2n
serial-number: 51FD049F496A
current-firmware: 3.17
upgrade-firmware: 3.17
[admin@mk01] > system routerboard usb pr
usb-mode: automatic
bootstrap: host-mode
[admin@mk01] > system routerboard usb power-reset
ERROR: USB power reset not implemented on this hardware
Kola
Mon Sep 08, 2014 10:31 am
If there's no way I think it should appear (some one should make) one to connect two network devices (say RB and PC) via USB-cable. All we need is some dummy modem driver to bring up PPP-connection.
It's kind of offtopic but third connection for mAP worth it.
P.S. Damn, I forgot RB probably can't be USB-slave at all. :(
janisk
Mon Sep 08, 2014 1:51 pm
you can attach this to powered USB hub and still use it as USB port.
It is not possible to establish a connection over USB cable.
tehdan
Wed Sep 10, 2014 11:54 am
Thanks - not quite what I was asking, decided to try any way. Turns out it works fine using a 5V USB power supply to power to the mAP and a USB device. I just used one of the y-shaped cables with 2 type-a connectors (the ones commonly used to give extra power to an external HDD). Now to find out how long the battery lasts...
janisk
Wed Sep 10, 2014 1:36 pm
what is the capacity of the battery?
tehdan
Wed Sep 10, 2014 1:44 pm
A lightly-used mAP ran for 5 hours on a 1800mAh battery using wifi/ethernet.
On the same battery powering the mAP and a USB modem (with an active 3G connection) it ran for 2:20.
neophyte
Fri Sep 12, 2014 2:30 pm
dlink des-3200-28p and dgs-1008p vs mAP2n poe dont work :? :(
pablo191f
Sat Sep 13, 2014 1:27 pm
What about WiFi range and link quality compared with rb951g-2hnd or rb751u-2hnd?
What is better for 60m^2 flat (only indoor usage):
Any ethernet router + mAP-2n
or
rb951g-2hnd?
Quindor
Sun Sep 14, 2014 1:21 am
or
rb951g-2hnd?
Looking at the spec sheet here and here the answer should be quite obvious.
Regardless of the power output (The RB951G-2HnD can output much more) the RB951G-2HnD has much better antenna's. As such, the RB951G-2HnD would be better suited for your indoor usage scenario.
A step up from that would be an RB2011UiAS-2HnD-IN or the new CRS109-8G-1S-2HnD-IN. Those are much better suited in a single Access-Point home situation kind of deal.
The mAP is more of a "I need something small while traveling" or other such purposes.
pablo191f
Sun Sep 14, 2014 11:10 am
Thanks 4 your answer. Now I have clear situation ;)
MMorris
Tue Sep 16, 2014 5:45 pm
NEED ADVICE!!! This looks like the perfect solution to my problem almost!
I need to make a mobile bridge that will connect to my existing wifi network and give a non wifi device access! The issue im trying to figure out is the user will not have access to the config page and needs a feedback that its connected to the wifi! I was thinking a beep script would have worked but looking at the posted hardware pictures i don't see any speaker built in! any advice on how to best do this? i see there is a AP lite and a actual wifi lite not sure if on would stay off when its not connected to a ap and turn on if it dose in client mode?? that would work.
jarda
Tue Sep 16, 2014 6:02 pm
Have you tried common USB wifi dongle for such purpose? Or why you need such router as client device?
MMorris
Tue Sep 16, 2014 6:13 pm
its a credit card machine no usb only has cat5 port!
ohara
Tue Sep 16, 2014 10:26 pm
You want to set up mAP as wireless client of an existing access point, and then you want to connect the credit card terminal to mAP via ethernet cable?
If you are looking for a visual notification on the mAP that it is actually connected to the access point, please check SYSTEM>LEDs on mAP. Check what options you've got there. I don't have a mAP, but I can see on the picture that it has a USR led. Check in config if you can program this user led based on wireless interface status.
MMorris
Wed Sep 17, 2014 12:18 am
I don't have one yet I'm trying to figure out if this is posoble before purchase or if someone has a recommendation for hardware I like the size of this!
tehdan
Fri Sep 19, 2014 12:05 am
The mAP already has a wifi LED - in station mode it will flash slowly while looking for a connection, and switch to mostly-on (flickering with activity) once connected. If you want to do something more idiot proof then you can use scripting. The mAP seems like the perfect device for what you're trying to do.
sbiddle
Mon Sep 22, 2014 1:36 am
I picked up one of these last week and love it.
One thing I'd love to see with this device (and over the years we've seen many people make the same comment for other models of hardware) is the ability to disable the reset button. It's far too easy for somebody to tamper with this if they really wanted to.
janisk
Tue Sep 23, 2014 12:02 pm
IMHO (as a user) if someone has physical access to your device (whatever it is) and he/she has malicious intent - security and integrity of the device goes down the drain. I wold not recommend to disable last resort recovery option.
bleomycin
Sun Oct 19, 2014 7:58 am
I'm looking to use these as a wireless bridge for some IP Cameras, I assume that shouldn't be a problem? Just wanted to make sure...thanks!
Begetan
Fri Oct 24, 2014 5:12 am
What is the current limit for USB port?
Is it possible to feed up strong 3G/LTE Modems?
janisk
Fri Oct 24, 2014 11:46 am
what is expected power draw at 5V for these "strong" SUB modems?
1A@5V is not a problem for mAP.
Valerio5000
Sun Oct 26, 2014 2:08 am
The device heats up a lot?
janisk
Mon Oct 27, 2014 2:52 pm
no. it does not heat up. You can press your hand against the router when it is working configured and loaded for max consumption and that is an unlikely scenario for the device.
jnygard
Sat Nov 29, 2014 10:13 am
Does Mikrotik have a specific reason why the USB port is a Micro-AB port? These type of ports break down quite easy as you can by mistake insert a Micro-B connector the wrong way. I would suggest that the port would be switched to a Micro-B port in the future...
dagelf
Wed Jun 15, 2016 8:12 am
routerboard: yes
usb-mode: automatic
This is an absolute dealbreaker for me... had big plans for this little router.
Unless I can figure out how to cycle the power... maybe a powered USB hub powered via POE, and then I can cycle the POE to power cycle the USB?... Should work, right? But there goes the size advantage unless I can find a miniature powered USB hub...
Dear Mikrotik.... can't you make the mAP support USB power reset? Or make something similar that does support it?
G2Dolphin
Fri Jun 17, 2016 4:17 pm
Looks like there's an upgraded version incoming — mAP-2nD. Probably it will.
But honestly dunno how it can support it while being able to be powered on from USB.
juliokato
Thu Jul 28, 2016 6:36 pm
I have two Routerboard mAP-2n, one the power reset usb is implemented and other nothing:
admin@5AC204xxxxxx] > /system routerboard print
       routerboard: yes
     serial-number: 5AC204xxxxxx
  current-firmware: 3.24
  upgrade-firmware: 3.24
[admin@5AC204xxxxxx] > /system routerboard usb power-reset
[admin@CAPS-MAP01] > /system routerboard prin
       routerboard: yes
     serial-number: 5AC202xxxxxx
     firmware-type: ar9330L
  factory-firmware: 3.17
[admin@CAPS-MAP01] > /system routerboard usb power-reset
But there is no reference on changes or hardware revisions of these two devices.
This is a problem in acquiring it is a lottery!!!
tyby
Tue Aug 02, 2016 4:27 pm
Guys, quick question(s) :)
I tried to search for info, but without success.
Can I use a mAP-2n ethernet ports in bridge mode with wlan interface? It would help me to reduce the cablings (I need an extra AP on my upper floor, I already have cable for TV and I would like to connect network cable to eth0, and a patch-cord for TV to eth1. And, of course, to keep wlan clients in the same network.
Second one: is the map-2n delivered with pOE injector? Or should I buy one along with the device? If no/yes, what type?
Thanks!
darkprocess
Tue Aug 02, 2016 6:09 pm
Yes you can bridge both interfaces and make it act as an ap.
It's not delivered with a poe injector. Mikrotik injector is recommended.
Envoyé de mon SM-G925F en utilisant Tapatalk
tyby
Tue Aug 02, 2016 6:57 pm
Thanks darkprocess!
darkprocess
Tue Aug 02, 2016 8:35 pm
Put your wlan interface in ap-bridge mode
G2Dolphin
Wed Sep 14, 2016 10:08 am
And it arrives! Interesting that mAP2n dissapear from official routerboard.com site.
Some differences besides dual-chain WiFi and more faster processor (QCA9531 on the new, AR9331 on the original)?
tyby
Wed Sep 14, 2016 7:49 pm
Guys, sorry for late reply, I had a very rough summer lately.
Thanks for info.
I just received my brand new mAP 2nD, erased default config, started from scratch.
And ... I don't get it to do what I want. For now I only have a pretty expensive 2 ports ethernet switch. Managed. :)
It seems that I cannot make wlan1 to be up. In bridge1 I have all interfaces, like this:
ether1 - designated port
ether2 - designated port
wlan 1 - disabled port (italic)
export below
# sep/14/2016 16:45:20 by RouterOS 6.36.3
# software id = GU9G-Z1DB
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=romania disabled=no mode=ap-bridge wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=password\
    wpa2-pre-shared-key=password
/ip hotspot profile
add bridge=bridge1 interface=wlan1
add address=192.168.0.253/24 interface=ether2 network=192.168.0.0
set servers=192.168.0.250,192.168.0.246
/ip dns static
add address=192.168.0.253 name=router
add distance=1 gateway=192.168.0.254
/system identity
set name=mAP-2nD
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
[admin@mAP-2nD] >
I searched the forum / wiki, but without much success.
I will continue, but maybe one of you have a quicker idea.
PS: scope of work: eth1-eth2-wlan in bridge, I don't need WAN, firewall etc. I just need an AP with 2 LAN ports.
Thanks!
tyby
Wed Sep 14, 2016 10:20 pm
In the meantime I've done a reset with default on, made my changes, saved config text, reset again without default, feeded the saved config and ... wlan is working now, still disabled port, but I can see wifi signal (and connect to).
I will keep it under eyes for few days and revert.
Thanks!
MartijnVdS
Thu Sep 15, 2016 10:11 am
There is a missing gap, I think they don't print out all Mac
On devices with multiple ports, they tend to only print the first and last mac addresses of the range.
normis
Thu Sep 15, 2016 11:02 am
Wireless will become "R" only when you connect to it. If you scan for networks, do you see it's SSID name?
tyby
Thu Sep 15, 2016 11:48 am
Hi Normis.
I think the post is addressed to me.
Now I can see the SSID, but - while writing my first post above - could not see nor the SSID set by me, nor the default SSID (Mikrotik-xxxxx), nor other "unknown" SSID.
For now, simple working config looks like below:
# sep/15/2016 11:37:26 by RouterOS 6.36.3
add admin-mac=E4:8D:8C:09:A4:42 auto-mac=no name=myBridge
/ip neighbor discovery
set ether1 discover=no
set ether2 discover=no
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=myWPA2 supplicant-identity="" wpa-pre-shared-key=password wpa2-pre-shared-key=password
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=romania disabled=no distance=indoors frequency=2452 mode=ap-bridge security-profile=myWPA2 ssid=mAP wireless-protocol=802.11
set wlan1 discover=no
/ip hotspot profile
add bridge=myBridge interface=ether2
add bridge=myBridge interface=wlan1
add bridge=myBridge interface=ether1
add address=192.168.10.251/24 interface=ether2 network=192.168.10.0
/ip dhcp-relay
add dhcp-server=192.168.10.254 disabled=no interface=myBridge name=relay1
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.251 name=router
add distance=1 gateway=192.168.10.254
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=mAP-2nD-frt01
/tool mac-server
add interface=myBridge
I really don't see critical changes from the one I posted above (but - with that one - SSID was NOT visible).
Hope this will help someone.
Cheers!
G2Dolphin
Fri Oct 21, 2016 5:10 pm
mAP 2n and mAP 2nD
It's hotter than previous 2n, probably because of heatsink attached. It can be overclocked to 750MHz and downclocked to 550 (2n can be only downclocked). Now there is voltage information in the System - Health (shows 4.6V being powered from USB). 802.3af PoE is working OK this time. :)
macsrwe
Fri Oct 21, 2016 11:50 pm
no, it will not have voltage monitor.
Routerboard.com says mAP has voltage monitor (click box under "Features"). mAP product page says mAP has voltage monitor. Winbox says mAP has no voltage monitor. Wish I knew whether this was a Winbox bug or a marketing bug.
troffasky
Sun Oct 23, 2016 12:46 am
So, in summary, can we pass 802.3af PoE in to the mAP2nD and get 802.3af PoE out of it?
janisk
Mon Oct 24, 2016 9:17 am
sometimes it would be useful to check at what date, month or year the comment is made. And maybe notice that most probably that is done for the previous revision in 2014.
macsrwe
Mon Oct 24, 2016 9:42 am
I understand the comment was old -- but both the Winbox resilts and the marketing literature at routerboard.com are absolutely current, they don't agree, and it would be nice for whichever is wrong to get corrected.
mjbop1
Wed Oct 26, 2016 12:52 am
What about a mAP AC lite with AF/AT power and 2-3 10/100/1000 ports
This would rock in a dorm room. If the price point could be around the hAP AC Lite
Arcticfox
Tue Nov 01, 2016 1:56 pm
Would be great to add USB-NIC mode - mAP gains 3rd Ethernet interface via USB.
G2Dolphin
Thu Nov 17, 2016 9:00 pm
Not sure about 802.3af in ether2, but an active PoE device turns on instantly and works well...
risk
Mon Nov 21, 2016 8:06 pm
hAP ac lite with gigabit ports and in a smaller package for the price of hAP ac lite
sure, I'd buy that!
I'd like it to be type-c
Arcticfox
Fri Nov 25, 2016 1:01 pm
sure, I'd buy that!
Yes, type-c would be optimal, but could port be more "compatible" with possibility of use micro-USB type-B compatible (depends from controller).
risk
Sat Nov 26, 2016 1:29 pm
+1 - Everyone has a handful of old micro-b chargers at home they're not using that can be given a second life.
troffasky
Sun Jan 29, 2017 11:48 pm
According to the manual for the Yealink W52P it is an 802.3af device, and I doubt that Cisco SB PoE switch is anything other than 802.3af, so I think your answer to my question is "yes"!
Arcticfox
Mon Feb 06, 2017 11:29 pm
Is any news about USB-NIC feature?
Arcticfox
Mon Aug 21, 2017 12:04 am
+ half year passed.
No answers...
troffasky
Fri Nov 17, 2017 6:45 pm
You could read between the lines as follows - this page has been obsoleted:
https://wiki.mikrotik.com/wiki/Supported_Hardware
in favour of this page:
https://wiki.mikrotik.com/wiki/Manual:Peripherals
so you could read that as no, no USB NIC support.
eriitguy
Thu Dec 21, 2017 4:42 pm
Hello, mikrotik team!
Please consider the following request for next upgrade of mAP:
1. Embedded LTE with SIM slot
2. 32 MB of storage
3. USB type C
Thank you!
StrataNet
Mon Aug 19, 2019 2:35 am
Unfortunately not (I've just tried this). I knew it would be a long shot (and would probably exceed the current that USB can put out) but just wanted to try it anyway.
However, the "PoE out" LED still comes on when powering from USB. MikroTik, may I suggest a firmware update to turn this LED off when powered from USB, to avoid confusion?
pothi
Mon Dec 06, 2021 7:36 am
Thanks for clarifying. I was just about to buy mAP. But, wanted to make sure it can power SXT with PoE when powered via USB. Yes, a firmware update would be nice.
Users browsing this forum: esj and 100 guests
