It was never advertised and not in any manual or specification sheet. Only one mistaken post in a user forum.Do you mean that this revision cannot be fixes by software to use IPSec Hardware encryption?
If yes you have to think about money return, because this look like aaaaa veerry huge fraud. We are discussing this routerboard 8 months, and suddenly you are telling us that this is not real? Really ?
"What a mistake-a to make-a!"Boys, are you really not reading device's official specs befor ordering ?
Have you read this ? http://wiki.mikrotik.com/wiki/Manual:IP ... encryption
1. yesFirst revision of RB850Gx2 will not have a IPsec encryption accelerator, as initially posted in this thread
Normis ... can you please answer these questions:
1. Is there going to be a revision of RB850Gx2 with IPsec encryption accelerator ?
2. When can we expect such a revision?
3. Will future revisions of RB850Gx2 still be fanless?
4. any other changes planned for future revisions that are not going to be included in first revisions (jumbo frames for example) ?
5. What IPsec throughput can we expect from the first revisions of RB850Gx2 without accelerator?
tnx in advance ...
JF.
Wow... I've been waiting all year for this!First revision of RB850Gx2 will not have a IPsec encryption accelerator
That would be great. It's more than most routers do with hardware encryption enabled.5. ~150-200Mbps
I have tested all types of encryption and the max I have achieved is 20mbps.5. ~150-200Mbps
Agreed. The IPSEC performance is awful. Both with PPPoE and L2TP I also only get about 20mbps. Am going to try to return these things. My RB951G-2HnD outperforms them.I have tested all types of encryption and the max I have achieved is 20mbps.5. ~150-200Mbps
What settings you have used ?
We have currently tested IPsec on the RB850Gx2, and the result is 550MBps with 1470 byte packets
Tunnel mode, aes-128, sha1, UDP traffic with 1450byte packetsI have tested all types of encryption and the max I have achieved is 20mbps.5. ~150-200Mbps
OK, Great ! What about TCP ? Same settings ? Please share the result.
Can we get some info about second revision? It is almost 3 months since your post.1. yesFirst revision of RB850Gx2 will not have a IPsec encryption accelerator, as initially posted in this thread
tnx in advance ...
JF.
2. hard to say, possibly within 6 months, but that is a wild guess
3. yes
4. hard to say, nothing specific at the moment
5. similar to any un-accelerated CPU at this frequency.
Can we get some more info about second revision? It is almost 3 months since your post.1. yesFirst revision of RB850Gx2 will not have a IPsec encryption accelerator, as initially posted in this thread
tnx in advance ...
JF.
3. yes
Easyli buy from Exar some smaller crypto Chips and then solder them on each non-Tilera based RouterBoard and we get even on all RouterBoards hardware crypto acceleration for VPN!Can we get some more info about second revision? It is almost 3 months since your post.1. yesFirst revision of RB850Gx2 will not have a IPsec encryption accelerator, as initially posted in this thread
tnx in advance ...
JF.
3. yes
I checked ipsec throughput RB850Gx2 with ROS 6.285. ~150-200Mbps
It would be grate to have real life test... Site to site ipsec with a GRE tunnel in it and routing between networks...Latest Mikrotik news 66 states that RB850Gx2 devices will now start shipping with HW encryption accelrated CPU. And 500Mbps AES througput should be achievable, sound like great news!
IMHO the new RB850Gx2 with hardware encryption should have been called RB851Gx2
Now If we want to buy the improved version of RB850Gx2 we need to ask our provider to know it's serial number
That's a good reason, but mind on customers. Now we have a problem due to this unchanged name of product. I see others manufacturers add a v2 or hardware spec 2 when they do a change like this."1" in the end will indicate that it has a wireless slot or card. + each change in product code results in new government certification for us, to import that product, so i'm against changing any names, especially in cases when there are no physical differences between boards.
This is just one small feature, and for 95-99% of customers it will be totally no difference. But those 1-5% that need it usually will know exatly what to look for in serial number.That's a good reason, but mind on customers. Now we have a problem due to this unchanged name of product. I see others manufacturers add a v2 or hardware spec 2 when they do a change like this.
The vortex suggestion of the K element in the name for future products it's a good idea.
What's a big or small feature is subjective to everyone's needs.This is just one small feature, and for 95-99% of customers it will be totally no difference. But those 1-5% that need it usually will know exatly what to look for in serial number.
The best MT reviews I've ever seen...First part of review RB850Gx2
http://lanmarket.ua/stats/obzor-Mikrotik-RB850Gx2
Part two have ipsec and l2tp performance test. Coming soon.
Thanks for the test results.Part 2, RB3011 vs RB850Gx2
http://lanmarket.ua/stats/testirovanie- ... 011UiAS-RM
RB850Gx2 in middle between old RB2011 and new RB2011.
Sorry, but I have just one RB850Gx2.I think the results would be more realistic if 2 RB850Gx2 where used for IPSec instead of RB850Gx2 <> RB3011.Part 2, RB3011 vs RB850Gx2
