Mon Jul 28, 2014 11:44 pm
It looks like a filter cap for a voltage regulator[Q200], probably 1.8v.
Most likely any 1uf ceramic will work (if you can get them new).
If you have any scrap electronics, you could post a picture, and we could point a capacitor you could salvage.
By the way it is positioned(There is another cap and an inductor in that voltage out/input), there is a chance the board would even power up, altough stability would be a concern.
If you could power the board and measure how many volts you get between the pads (from the broken cap), it would be easier to know what that rail is powering
