Code: Select all
RouterBOOT booter 3.13
CCR1016-12G
CPU frequency: 1200 MHz
Memory size: 2048 MiB
NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Could not mount ubifs filesystem: Structure needs cleaning
opendir: No such file or directory
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
Starting stack dump of tid 1, pid 1 (init) on cpu 15 at cycle 15173358619
frame 0: 0xfffffff7004ef9e8 dump_stack+0x0/0x20 (sp 0xfffffe003d26fc08)
frame 1: 0xfffffff7004e8c68 panic+0x168/0x388 (sp 0xfffffe003d26fc08)
frame 2: 0xfffffff700050e68 do_exit+0x1c8/0xd48 (sp 0xfffffe003d26fcb0)
frame 3: 0xfffffff700051b30 do_group_exit+0xf0/0x1e8 (sp 0xfffffe003d26fd78)
frame 4: 0xfffffff700051c48 __wake_up_parent+0x0/0x18 (sp 0xfffffe003d26fdb0)
frame 5: 0xfffffff7004f05c0 handle_syscall+0x210/0x2d0 (sp 0xfffffe003d26fdc0)
<syscall while in user mode>
frame 6: 0x735d0 0x735d0 (sp 0x7fa8faa8)
Stack dump complete
Client requested halt.
