please see sad result of idiot_at_work - one image is better than thousand words:
As you can see, whole LAN connector is missing because it has been pulled out of a board.
Because data paths were damaged it is likely impossible to solder connector back.
Only way to solve problem is probably to solder wires between connector <-> appropriate pins.
So, I'd need either scheme of the board(I guess nobody give it to me) or an advice where to solder ends of wires from LAN connector.
Please help!
