hi every one ...i have the sextant type g
http://routerboard.com/RBSEXTANTG5HPnD
i thing it have a proplem ...the sextant disconnect = the lan stope working
it does not work again unless i reset it
it works for somedays and the the lan stop again and so on ...anyone help me
[sarcasm] did you plugged in power supply?
Anyway,
How we can help you, if you cant technically explain detailed: what environment, ros version, config, other end of link???
so lets explain the issue
i use the sextant as point to point link .i have two pieces of the sextant
the first as bridge point ( the master point ) and the second as station wds point ( the slave point )
the proplem is in the master point ( the lan of it ) you can not access the master point because the lan stop working unless you reset it from the downside button that found in the routerboard ......and that is all
