C'mon, dudes...
Am I speaking chinese here?
Let me talk to you in pretty pictures then:
> /system ssh 10.255.255.8 user=admin
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.20 (c) 1999-2014 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@SB-ScreenLeft-2G] > /system resource print
uptime: 1w8h38m23s
version: 6.20
build-time: Oct/01/2014 10:06:12
free-memory: 44.5MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 0%
free-hdd-space: 5.3MiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 159
write-sect-total: 1284
bad-blocks: 0%
architecture-name: mipsbe
board-name: RBcAP2n
[admin@SB-ScreenLeft-2G] > /system upgrade
[admin@SB-ScreenLeft-2G] /system upgrade> export
# jan/09/1970 09:33:41 by RouterOS 6.20
# software id = RC64-4A6Q
/system upgrade upgrade-package-source
add address=10.255.255.254 user=upgrade
[admin@SB-ScreenLeft-2G] /system upgrade> refresh
[admin@SB-ScreenLeft-2G] /system upgrade> print
# SOURCE NAME VERSION STATUS COMPLETED
0 10.255.255.254 routeros-mipsbe 6.21.1 available
1 10.255.255.254 wireless-fp 6.21.1 available
[admin@SB-ScreenLeft-2G] /system upgrade> download 0
failure: not enough space on disk
[admin@SB-ScreenLeft-2G] /system upgrade> #FIX PLS KTHXBYE
So what did I do wrong? Maybe I should dance for a while before hitting enter?
