Does CRS109 (corrected - before was crs1009) series desktop switches have wallmount holes on the bottom? I can't find anywhere a photo of its underside.
Anyone able to post a relevant photo for that?
Thank you!
Yes, all CRS units have rack ears, including the small desktop ones.sorry, i was talking about crs109 desktop switches. Do they also contain these rack ears?
thank you for the fast reply!
Does the CRS109 have screw holes on the sides that rack ears can be fastened to? If they don't then KillerOPS would be required to drill holes into the sides of his CRS109 in order to put ears on it.You are right, I made a mistake, only the CRS2xx series have rackmount brackets in the box
Maybe there is another rackmount product that you have access to, that doesn't need the ears? You could ask the seller if they have the ears available separately
