I need an external antenna to increase the signal of a mAP2n routerboard.
I've open the unit and a saw a very small connector on the board on the side of the heat sink.
Does anyone knows if it is possible to connect an external antenna on that connector? If yes what kind of connector is this?
Is there any other way to add an external antenna to the equipment?
thanks
