I have a problem with Ethernet port on a few SXT AC 90° and RB912UAG-5HPnD. Connection over ethernet port is lose but link is ok (not down). Wifi part is ok and clients are connected. I have to reboot the device, and then everything is okay for a few days. I tried the version 6.19 and 6.25 and no change. Both routerboard are connected to a port on 250GS or 260GS (1.14). The devices use OSPF, simple firewall and nothing more.
Do you have someone similar problem?
Thanks for reply.
