For quit sometime i` m using serveral Mikrotik routers and today i have rebooted a RB450G running firmware 3.10 and RouterOS 6.28 but it did not succeeded the reboot. The router is not coming back online.
After some trial and error i found out that when i push the reset button and apply power to the router it will boot fine and everything is working. But on a second reboot the router is not booting. I already upgrade firmware to 3.22 and RouterOS to 6.29.1 but the problem is still there
The error message change when upgrading the firmware or RouterOS
Code: Select all
[admin@mt2] > system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Rebooting...
Stopping services...
Restarting system.
RouterBOOT booter 3.22
RouterBoard 450G
CPU frequency: 680 MHz
Memory size: 256 MiB
NAND size: 512 MiB
NAND partitions: 6
Press any key within 2 seconds to enter setup..
writing settings to flash... OK
loading kernel from nand partition 0... OK
setting up elf image... OK
jumping to kernel code
opendir: No such file or directory
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 1 seconds..
RouterBoard 450G
NAND size: 512 MiB
NAND partitions: 6
loading kernel from nand partition 1... kernel not found
loading kernel from nand partition 2... kernel not found
loading kernel from nand partition 3......... kernel not found
loading kernel from nand partition 4... kernel not found
loading kernel from nand partition 5... kernel not found
RouterBoard 450G
NAND size: 512 MiB
NAND partitions: 6
loading kernel from nand partition 3........ kernel not found
The difference when using the reset button:
Faillure
RouterBoard 450G
NAND size: 512 MiB
NAND partitions: 6
Success
RouterBOOT booter 2.23
RouterBoard 450G
Authorization: Passed
Memory size: 256 MB
trying bootp protocol..................................................................................................
