UMarcus
Wireless Product recommendation, small distance, low latency ?
Tue Jun 16, 2015 1:50 pm
i want to connect two Buildings via 5GHz P2P, Distance ~80m, Wireless Stations would be mount outside the Building A and inside the Building B behind the outside Wall.
I looking for a solution with lowest Latency, Bandwidth is secondary but should min. real 10MBit.
I plan to use the SXT 5 lite. But I’m not sure because one Station will be behind the Wall and the distance is very small ?
Any recommendations / comment’s ?
Thanks,
regards
Marcus
jarda
Tue Jun 16, 2015 7:50 pm
With brick or wooden wall it would work most probably. You can try also 2.4g version of sxt that could perform better through the walls.
UMarcus
Re: Wireless Product recommendation, small distance, low latency ?
Wed Jun 17, 2015 9:41 am
Many thanks for your response.
I will give the SXT5 a try, because the 2.4GHz is heavy used in the hood.
Did you expect some problems because the distance is to near, i have read that this could be a problem for station who are designed to bridge km's ?
Regards
Marcus
CyberTod
Long time Member
Long time Member
Wed Jun 17, 2015 9:46 am
It depends on the signal, but the wall will lower the signal. There is no problem if you adjust the power levels.
UMarcus
Wed Jun 17, 2015 2:02 pm
Many thanks for you answers, i will order the SXT 5 lite.
Cheers
Marcus
UMarcus
Fri Jun 19, 2015 2:03 pm
Users browsing this forum: No registered users and 82 guests
