It is very strange.
According to the general switching rules in this case frames should be flooded (similar to a broadcast frames). Or new entry replaces the oldest entry in the table; both processes are usually invisible to the user.
Blocking does not occur ever.
/interface ethernet switch port unset ether1 learn-limit
/interface ethernet switch port set ether1 !learn-limit
