conchalnet
Bandwidth control - Limit At and Max Limit
Thu Nov 03, 2005 3:48 pm
Hi all,
I started to use mikrotik since a month and now I need to control the bandwidth for each client mine.
I'm thinking in use simple queues to do this control. I don't know waht's the best form to do this control and I want the opnion of all.
I've three bandwidth values:
Upload/Download
64Kbps/128Kbps
64Kbps/256Kbps
128Kbps/512Kbps
What's the best form to configure the queues for each client and what is the best queue type to be used in this case?
How do I must configure the Limit at and Max limit??? PS: My clients have a shared link with CIR of 64Kbps.
PS: I'm using the mikrotik in ap bridge, because I've three towers in my city and just one gw to my network.
Thanks in advance
sergejs
Thu Nov 03, 2005 3:54 pm
you may use queues (pcq queues), and mangle to mark with 3 different marks users.
(because you have 3 different bandwdith limits)
conchalnet
Thu Nov 03, 2005 4:04 pm
OK sergejs,
But I want to use simple queues and create a queue to each client. In this form I'll be able to see the current traffic of each client on the queue.
I want to know what is the best form to configurate the simple queue to control the bandwidth of download and upload.
sergejs
Thu Nov 03, 2005 4:09 pm
one simple queue for one client, here are configuration examples:
http://www.mikrotik.com/docs/ros/2.9/ro ... ent#6.54.6
conchalnet
Thu Nov 03, 2005 8:37 pm
sergejs
How is you opnion about how I've to configure the parameters limit-at and max-limit???
How I saw in the first question my clients have a shared Internet link with CIR of the 64Kbps.
Thanks again
pedrogn
Fri Nov 04, 2005 1:59 am
Hi Fabricio (are you brazilian too?)
I supose that you are using mikrotik that same way i do. Are you a wISP?
I currently use simple queue to control the bandwidth of my customers, for example:
open the terminal console and type:
queue simple <enter>
and type:
add name="Apto444" target-addresses=10.10.4.44/32 dst-address=0.0.0.0/0 interface=ether2 parent=none priority=8 queue=default/default limit-at=64000/128000 max-limit=64000/128000 burst-limit=128000/192000 burst-threshold=32000/32000 burst-time=8s/8s total-queue=default
doing this, open the winbox interface on queues, and you will see and undestand how to create this by winbox.
you can use limit-at and max-limit with same value.
the bust parameter is optional, but it is a good ideia cause the web navigation will be improved and your customer will be dazzle.
conchalnet
Fri Nov 04, 2005 4:41 am
Hi pedrogn,
I'm Brazilian yep! are you too???
What do the bursts parameters do exactly???
And if i use the limit-at and max-limit with the same value what will happen when my backbone is full??? How does the mikrotik divide the bandwidth in this situation??? The limit-at is not the CIR???
I'm from Conchal/SP :), where I've a WISP :(, if you interesting in contact me my email is:
fabricio in conchalnet.com.br.
Regards
sergejs
Fri Nov 04, 2005 9:20 am
first goes max-limit, if there will be not enough resources, than accordingly goes limit-at.
about burst, you read queue documentation.
larmaid
Fri Nov 04, 2005 10:02 am
@pedrogn
add name="test" target-addresses=10.10.x.x/32 dst-address=0.0.0.0/0 interface=ether2 parent=none priority=8 queue=default/default limit-at=64000/128000 max-limit=64000/128000 burst-limit=128000/192000 burst-threshold=32000/32000 burst-time=8s/8s total-queue=default
the interface= inbone / outbone......?
and the result:
sometimes upload rate is bigger then max-limit and the queued bytes shows 0/0 B.
and can u tell the easy way what is burst-limit,burst-threshold n burst-time do for sure....!i read the manual i still dont get it.....?
i like it
Users browsing this forum: David1234, Enics, Google [Bot], hamed5034, hci, TomjNorthIdaho and 24 guests
