AC is not as good as I would expect. Either PTP or PTMP. I have one mixed N/AC PTMP with SXTac SA as an AP and dont have any single issue with it, there is just 5 clients though...It's not that I complain on wireless capabilities of mikrotik gear. It's kind of observation I made. About year ago after I got dissapointed by 802.11ac support from mikrotik I decided to use other producer equipment. The other one that gave me so much enjoyment to work with. But lately I was forced to upgrade some older links, and gave mikrotik one shot more.
Dynadish 802.11ac met my expectations. I was very happy to see nicely working ptp on new software 6.30.4. after few weeks I decided to upgrade other AP, mostly omnitiks. and here we are, what is wrong with.... multipoint mode?? It's a disaster! after day or two it eventually stops passing traffic to clients. neither auto nor 2ms mode helped. Omnitik AP, 12 apc connected, subscribers up to 16mbps, wireless data rate 39-78-90 some with dual polarization even 180mbps.
on the client side speedtest.net shows...3mbps and significant loss of packets. jitter is over reasonable range.
channel under spectral scan is totally clear.
Your rates doesn't seems to prove you have clear channel, sorry. Also mixing SISO and MIMO clients is not good practice.
Btw. I did have one OmniTik in my network, but would not recommend it. Antenna gain is too low and after 2 years I had issues with signals on one polarization so I guess the antenna started to fail. Replaced with 13dB OMNI from U***, put 711GA on it in metal box from RFelements and all works well.
