I'm trying to set up a (pretty simple I thought) usecase.
I would like to open a CAPsMANv2 managed wifi SSID to authenticated users for which I would expect to use WPA(2) EAP.
Now I also understood that for EAP you usually require a RADIUS server and also learned that userman should provide simple RADIUS services. I also found what I think is the radius client configuration under Radius in webfig.
But I think I'm still missing some bits and pieces inbetween since I couldn't get it to work.
Is there any pointer to some howto to show a setup as outlined above?
Thanks,
Wolfgang
