I know is impossible to have two configuration (AP and Station) working together, but I use my router 75 as AP with virtual AP and 25% like Station and routing the internet for certain IP across the WLAN1 (Station).
I realise I can't have the configuration for AP disable and the client enable, or AP enable Station disable.
I need to edit everything. delete the virtual AP and change the AP to station.
Is possible to have one disabled and the other working and turn around?
Is a best way to have both configuration saved?
Thank you
