Arcee
Colocation Question
Tue Dec 01, 2015 2:35 am
So, imagine three sites. A, B and C; Site B connects to both Site A and C.
Will I have less interference issues is I put a AP and a Station at Site B? That is, Site A will have an AP and Site C will have a Station.
I'm comparing this to: Two APs at Site B and a station at Site A and Site C.
Hope my question makes since. Essentially, I'm asking if avoiding two APs at a single site make a difference with colocation interference.
Arcee
Re: Colocation Question
Mon Dec 07, 2015 4:18 am
Tough question?
jarda
Mon Dec 07, 2015 8:30 am
Not at all. Everything depend on local situation. Use directional antennas with different frequencies on both links, place them at least 1m away from each other on the site B and there will be no problem.
You can put some grounded metal sheet between the two devices on site B to be absolutely sure.
Arcee
Mon Dec 07, 2015 3:21 pm
My question is... Will two APs on a pole interfere with each other just as much as an AP and Station on the same pole. All other variables remaining the same... Spacing, weather...etc.
Sent from my SM-G920I using Tapatalk
jarda
Mon Dec 07, 2015 5:09 pm
As the links are both point to point, it doesn't matter.
ZeroByte
Re:
Mon Dec 07, 2015 7:49 pm
Both radios will spend time sending and receiving. Moments where radio1 is listening while radio2 is transmitting could cause interference if you're not following best practice for installations, channel planning, etc - it doesn't matter which is the AP and which is the station.
If you're using a frequency duplexing sytem, (such as Nstreme dual) then you can make all transmitters use the same frequency because they can't interfere with each other.
Arcee
Mon Dec 07, 2015 11:53 pm
Understood. Thanks guys.
Users browsing this forum: No registered users and 67 guests
