Does WPS Physical button on RB951Ui-2HnD work for anyone?
Update: 04.03.2016:
I have now managed to get it to work on hAP with a short push, but for some reson it does not seem to work on: RB951Ui-2HnD. Even if I do it in the exact same way!????
I have tried to setup my SoHo routers with WPS, setting it to "Push button", but however short long or repeated I push the resetbutton to get it to activate WPS session on the router, I do not seem to get it to work?!
But if I use the "Virtual button" in Winbox the clients connect flawlessly with no problem, and WPS works as intended.
Has anyone else encountered these problems??
And if so, did you find a solution or fix for the problem??
