Maggot
Re: Wireless product max distance
Wed Nov 23, 2016 11:23 pm
Thanks for answering!
I'm sorry for the attachment, this is my very first post here
https://goo.gl/photos/KL8Z2o2PYfVupTza7
I first thought on using LHG-5 but I'm afraid would be at the edge of operational distance, according to the guide you mentioned.
Seems to be quite clean path, also the spectrum there.
Maybe should I do a Fresnel zone study? Perhaps https://www.loxcel.com/3d-fresnel-zone
Btw, the mounting on one site is likely to be on a F.M. broadcasting mast.
I don't think this suppose any issue, do you?
Regards
Héctor
pukkita
Trainer
Trainer
Fri Nov 25, 2016 12:57 pm
You should definitely do a Fresnel study. This Calculator can be used for free.
FM environment is going to give you ethernet link issues, you'll need ferrite beads that cover 25-150MHz range for any ethernet cables involved.
Maggot
Sat Nov 26, 2016 3:42 pm
Thank you so much pukkita, my boss is considering to set up a test link at a similar distance for performance evaluation.
I'll let you know any further advance
Best regards
Héctor
Malivanna
Tue Dec 20, 2016 4:52 pm
So have role that graph
TomosRider
Thu Jan 12, 2017 10:54 am
Listen to Pukkita, he's an old school network cat and knows stuff.
Second, i suggest Dyna Dish as reliable and quality solution for covering such distance. I have couple of links that performs smooth for almost six months now.Never had any problems.
Cheers!
pukkita
Trainer
Trainer
Thu Jan 12, 2017 12:48 pm
Best regards
Héctor
Sadly wireless is all about the location. You can setup a test link on spectrum free locations, and get full throughput; then mount the same equipment on its definitive location and barely be able to get decent throughput on any channel due to interference; beware specially of nearby, or pointing to your equipment Airfibers 5, they can wipe out the entire spectrum, specially if badly setup.
If your location spectrum is crowded (i.e. there are more PTPs in that tower) QRT can have an advantage vs DynaDish; performance with both is very close, but QRT seems to stand nearby interference better than the dynadish (better shielding).
The best shielding option in crowded towers is mANT30 PA + Sleeve30. Add a netmetal as radio and use a fiber run on the FM tower and you'll have the best setup in terms of resiliency.
Where's the internet source located? at the FM tower?
twebb
Mon Jan 22, 2018 11:56 pm
What happened to the tables in the first post? Every time I click on the link it takes me to the main MikroTik download page.
GOMAN
Fri May 11, 2018 2:57 pm
same here!
Also cannot download the PNG files.
nest
Forum Veteran
Forum Veteran
Fri May 11, 2018 4:31 pm
They've gone. :( Just use this instead https://mikrotik.com/calculator
Joni
Wed Jun 17, 2020 8:20 pm
The tables have been moved to product documentation download tabs:
https://mikrotik.com/product/lhg_2#fndtn-downloads
And a separate LHG 5 document which is stripped from the current brochure https://i.mt.lv/cdn/rb_files/LHG_5_all-180130154020.pdf
However not updated since 04/04/2016...
And since Mikrotik likes hide information here and there we might want to reference this at the same time https://mikrotik.com/products/matrix
normis
Thu Jun 18, 2020 8:22 am
There is also this link on the product page: https://mikrotik.com/products/ptp
Users browsing this forum: vic666 and 33 guests
