few years ago in ROS 5.xx, it appeared possibility to set desired channel bandwidth instead of standard 10/20/40MHz channels by setting of custom channel bandwidth in Wireless menu with a step 1 MHz!
This way you was able to make ETSI channel spacing like 7,14,28,56MHz with ,5 centre frequency step.
It is much better possible to coordinate and plan sites and the use those radios for special purposes. unfortunately this function was coded only for chipset 92xx, not any more for 93xx,94xx,95xx chipsets..
There is not possible to make 10MHz channels any more
Is there anybody who misses this functionality ?
