DenisVS
Questions about Mikrotik SXT lite5
Fri Apr 22, 2016 9:45 pm
Hi!
Now i have got a two Mikrotik SXT lite5!
I wanna install them properly.
Inside the cover we can see the ground screw. Where should be connect it: to the mast or to the power supply/switch/pc chassis?
How to protect the device from the rain or snow? I wanna desgise the device from the thiefs too… May I use a plastic bag cover?
DenisVS
Re: Questions about Mikrotik SXT lite5
Tue Apr 26, 2016 11:01 pm
Silence :D
Next question.
Which type (specification) of power connector used in PoE injector?
I bought the plug in electronic shop, but it provide not very well connection unlike the plug in the power supply which is very good.
jarda
Tue Apr 26, 2016 11:42 pm
There is grounding video on the product pages. http://routerboard.com/RBSXTG2HnD see it. There is big ideology discussion about the grounding. You should do it because it is suggested by manufacturer but I have never done it with no negative effect. Use 5.5mm /2.1mm jack. You can use the plastic bag over the device. Just take care about the temperature in a hot summer day.
chechito
Wed Apr 27, 2016 12:48 am
Users browsing this forum: Bing [Bot] and 83 guests
