It was my understand that when you disable (or uncheck in winbox) the Default Forward option, (for a wireless interface), this keeps any devices connected to that wireless interface from communicating DIRECTLY with each other?
However, i have 2 x PCs, and connected them to a MT radio, with Default FW off, yet they can still ping each other.
Do i have this incorrect? or is something not working as it should?
ROS 6.32.3 on a RB 433 Both devices are on the same subnet (192.168.1.X / 24) and both devices are able to access the internet (both with default forward on and with it off, as they should).
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce \
default-forwarding=no disabled=no mode=\
ap-bridge name=wlan2-5Gn radio-name=5g-R52hN-D4CA6D132949 rx-chains=0,1 \
security-profile=mainWPA2only ssid=HouseN-5gN tx-chains=0,1 \
wireless-protocol=802.11 wmm-support=enabled
thanks
