I am thinking to use a few APs (wAP ac or NetBox) in an outdoor situation where no cable is possible (only power).
The easy solution would be to set them up as repeaters, that works quite good.
However, for maintenance I would also like to be able to change the wifi settings (mainly passwords) sometimes.
Can I do this via CAPsMAN??
I thought about having 2 SSID, one on physical wifi with fixed / long password (maybe even invisible) where the APs connect upstream as station, and one virtual for the wifi clients as AP.
But it seems CAPsMAN only works on the physical interface...
Is there a way to do this??
Thanks,
Gabriel
